Counter up/down
Guest #6185226
I will use seven segment display to show the numbers, but I also must be
able to set a specific time by increasing/decreasing and then once it is
set, with another button the clock will start to go down.
signal lock is for preventing the count increases at the speed of the
manual is a button,
I guess the count up is okay, but the problem is when I want it to go
down. In the simulation when I put the sentido HIGH then I do not get
anything and does not work.
library ieee;
use ieee.std_logic_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity counter is
port(   clck, reset : in std_logic;
        limit   : in integer range 0 to 10;
        manual: inout std_logic;
        sentido: in std_logic;
        bitcount : out std_logic_vector(3 downto 0);
        clckout : out std_logic);
end counter;
architecture behavior of counter is
signal Cs : std_logic_vector(3 downto 0):="0000";
signal lock: std_logic;
begin
Count : process(clck,reset,manual,lock,sentido)
    begin
            if(rising_edge(clck))then
             if (manual='0' and lock ='0') then
                      Cs<=Cs+1;
                       lock<='1';
             elsif(manual='1' and lock='1' ) then
                     lock<='1';
             else
                     lock<='0';
                    end if;
30
                    end if;
31
32
    if sentido = '1' then
33
                 Cs<=Cs-1;
34
                    end if;
35
36
            if (reset = '1') then
37
                    Cs <="0000";
38
                end if;
39
                if (Cs = "1010") then
40
                      Cs <= "0000";
41
                end if;
42
end process Count;
43
bitcount <=Cs;
44
45
end behavior;
Moderator (Company: Titel) #6185669
John wrote:
> In the simulation when I put the sentido HIGH then I do not get anything
Absolutely NOTHING?
> and does not work.
What does your simulation show instead of the desired reaction?
What you built there is a combinatorial loop, because the Cs<=Cs-1
path has no clock!!11one!eleven!11
Where did you find this very strange way of a synchronous process? How
do it all the others around the world?
Try this and think about it:
-- only the clock and (if absolutely necessary) the reset in the sensitivity list of a synchronous process!
Count : process(clck,reset)
    begin
      -- the reset path (is it really necessary?)
              Cs <="0000";
      -- the one and only clock for the synchronous path
      elsif rising_edge(clck) then
                      Cs<=Cs+1;
                       lock<='1';
                     lock<='1';
             else
                     lock<='0';
             end if;
                  Cs<=Cs-1;
             end if;
             if Cs = "1010" then
                      Cs <= "0000";
             end if;
      end if;
end process Count;
BTW: pls use the [vhdl] tags to wrap your VHDL code.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
