Serial/parallel converter VHDL
OP #6130963
i have an exercise to solve. The specifications are this:
-input serial_in that receives the input bit
-input clock 1200 HZ
-input reset
-output ready
-output parallel_out, a word of 16 bit
the input serial_in read 300 bit/s and present 16 bit on the
parallel_out and set ready = 1. The convertitor remains in this state
until reset = 1 and clock = 1 (rising edge), in this case starts a new
conversion.
I write the following VHDL code. I would to know if it's a correct and a
possible solution:
library ieee;
use ieee.std_logic_1164.all;
entity convertitore is
  port(serial_in, clock, reset: in std_logic;
      parallel_out: out std_logic_vector (15 downto 0);
      ready: out std_logic);
end entity convertitore;
architecture device of convertitore is
  variable output: std_logic_vector(15 downto 0);
  begin
    clock: process
    begin
      clock <= '0', '1' after 416.5 ms;
      wait for 833 ms;
    end process clock;
    main: process(clock, reset)
    begin
      if(ready /= '1')
      then
        for i in 0 to 15 loop
          output(i) := serial_in;
          wait for 3.5 ms;
        end loop;
        parallel_out <= output;
30
        ready <= '1';
31
      end if;
32
33
      if(clock'event and clock ='1') then
34
        if(reset'event and reset = '1') then
35
          ready <= '0';
36
        end if;
37
      end if;
38
    end process main;
39
  end architecture device;
Thank you
Guest
> possible solution:
No. This is a mixture of a testbench and something else. Why do you have
a clock input and then generate the clock internally? Why do you trigger
on the rising edges of reset AND clock? And what do you expect when the
for loop in the main process is executed? Have you tried a simulation?
I think you should have a very deep look into your VHDL course material
and start with simpler examples. Write a testbench and a
device-under-test and have clear interfaces between them. And make
yourself familar with the use of processes. And avoid using variables as
long as you are a VHDL beginner.
OP
I need to generate the clock, now i separate a "clock generator" and i
understand the error.
I also understand that in my case i don't need the sensitivity list,
because i check inside the process the value of clock and reset.
i didn't undestand the error on loop....
OP
Something like this:
"i" is a integer counter initialized to 0
"int_clock" is the internal clock for 300 bit/s
"clock" is the clock input
   main: process
    begin
      if(ready /= '1')
      then
        if(int_clock'event and int_clock = '1') then
          i := i + 1;
        end if;
        if(i = 15) then
          ready <= '1';
          i := 0;
        end if;
      end if;
          ready <= '0';
        end if;
      end if;
    end process main;
Moderator (Company: Titel)
Which error?
The major problem here is, that you are "programming" VHDL like a
procedural programming language (e.g. C, Basic, Java). That will not
work. Never!
VHDL is a hardware DESCRIPTION language. And to DESCRIBE something you
must have a picture of it.
Start with a simple counter mapped to LEDs, simulate it and transfer it
to hardware. Have a look at the RTL-schematic. It shows you, how the
synthesizer did understand your DESCRIPTION.
Then change the counters code to count up while a button is pressed and
to count down while the button is released.
Then sync in and debounce the button and use it to count up your
counter.
Validate your solutions always with a testbench before going on
hardware, and have a look at the RTL schmematics.
A few words to some line of your code:
Have a look how a testbench invokes a "device under test". You will need
knowledge about components for that.
This here is nuts:
          ready <= '0';
This will never go into real hardware, because it is impossible in two
ways:
1. never ever you will have two rising edges of two signals at the
very same moment.
2. there is no "double clock flipflop" with two seperate clock inputs on
any FPGA/CPLD.
Having a second look, the whole code here is nuts:
   main: process
      begin
   end process main;
Its a process with no sensitivity list, it invokes three clocks, a latch
for parallel out and last, but not least: an async combinatorial reset
for ready. Each of them is bad, all of them together a valuable reason
for "you are fired!"  ;-)
Is the serial data synchronous to the input clock?
Looks like with every 4 clock cycles 1 data bit comes in.
Whats the systems clock? 1200Hz? Or xxMHz (with xx in 10..100)?
Whats the target hardware? FPGA? CPLD?
BTW:
Forget loops and variables. You don't need them here in this simple
project.
OP
Can i simulate my code in hardware with Quartus prime? Or i need a
physical hardware? I'll write the solution on a paper during the exam, i
don't have the simulator....
How can i use the same clock (or a fraction of it) for two different
purpose?
Yes clock is 1200Hz. I could count the rising edge and when i reach the
fourth i'll read the input? In this way i need a variable. I don't
understand why i can't use variable also on a simple project. If the
specifications tell me that i'll present the output after reading 16 bit
i need to save this 16 bit and THEN present it on parallel out.
You get some kind of ModelSim with it.
> Or i need a physical hardware?
As I said: physical hardware i the last step.
Aha, the software programmer.
I myself (as the hardware guy) would use some flipflops to store values.
Those flipflops arranged together in a proper manner result in a
counter. And that ist, what you need.
Be sure: a variable in VHDL is not what you need. A variable in VHDL
behaves somewhat strange to software programmers.
Meanwhile I did a little fingertwist and it resultet in the attachments.
As expected the synthesizer says it eats up 23 flipflops: 16 for the
parallel_out, 4 for the bit counter 0..15, 2 for the cycle counter 0..3
and one for the ready-flag.
Don't try to serve this pieces of code to your teacher. She/he will get
distrustful. Just use it as a "howto" to get the idea...  ;-)
Of course you can use my testbench to check your design. Thats the
trick: when the testbench is ok, you simply must get your module to go
through without an error.
OP
Thank you. I had already corrected my code like sipo.vhd with the only
difference that I used variables instead of signals. So every time I
think of using a variable I could replace it with a signal? Will this
serve for the next test bench? Probably we used variables because it's
not required the test bench during the exam, but i know that is not a
good cause.
I'm a computer science graduate, that's probably why I struggle a bit ;(
Just being a little bit nosy: can you post that code? ;-)
> with the only difference that I used variables instead of signals.
> So every time I think of using a variable I could replace it with a signal?
> Will this serve for the next test bench?
Of course you can do the same with variables. This code together with
the test bench from yesterday gives the very same output:
architecture Behavioral2 of sipo is
begin
   process (clock, reset)
   variable ccnt : integer range 0 to 3  := 0; -- cycle counter for dividing the clock by 4
   variable bcnt : integer range 0 to 15 := 0; -- bit counter for the 16 bits
   variable rdy : std_logic := '0';
   begin
      if reset='1' then
         rdy   := '0';
         ccnt  := 2;   -- in the middle of those 4 clock cycles we have a stable signal
         bcnt  := 0;
      elsif rising_edge(clock) then
         if rdy='0' then  -- not yet finished?
            if ccnt<3 then         -- do we have enough clocks for the next bit?
               ccnt := ccnt+1;     -- no: count on
            else                   -- yes:
               ccnt := 0;          -- reset cycle counter
               parallel_out(bcnt) <= serial_in; -- store the bit
               if bcnt=15 then     -- do we handle the last bit?
                  rdy := '1';      -- yes: were done!
               else
                  bcnt := bcnt+1;  -- no: increment index
               end if;
            end if;
         end if;
      end if;
      ready <= rdy;        -- map internal ready signal to output
30
   end process;
31
32
end Behavioral2;
The major drawback with variables is, that they are invisible outside
the process.
> Probably we used variables because it's not required
> the test bench during the exam, but i know that is not a good cause.
Particularly for learning VHDL the use of the simulator is absolutely
necessary. Its the FPGA debugger.
OP
This is my code. I use also a variable for the output because if i need
to present the output only when i read the 16 bit, i can't store the
single bit directly in the output, isn't it?
library ieee;
  port(serial_in, reset, clock: in std_logic;
  variable count: integer range 0 to 15 := 0;
  variable rising: integer range 0 to 4 := 0;
  begin
    main: process(clock)
    begin
      if(clock'event and clock = '1') then
        if(reset = '1') then
          ready <= '0';
        end if;
        rising := rising + 1;
      end if;
      if(ready /= '1' and rising = 4) then
        rising := 0;
        if(i = 15) then
30
          ready <= '1';
31
          i := 0;
32
        else
33
          i := i + 1;
34
        end if;
35
      end if;
36
    end process main;
37
Few words to your code (which would result in a reasonably bad grade
when I was your teacher...;-)
Its a bad idea to combine synchronous and asynchonous parts in 1
process:
    begin
      if(clock'event and clock = '1') then -- clocked section
      end if;
      if(ready /= '1' and rising = 4) then -- combinatorial section
      end if;
    end process main;
For sure you will not see this coding style in any book.
Beside the fact, that you cannot read back the output port "ready" you
have a incomplete sensitivity list due to that special coding style.
Therefore the simulation will not match the reality.
Much worse is, that you have a combinatorial loop on the variable i. And
the simulator is not possible to show it. Because i should be in the
sensitivity list, but variables cannot be taken in there, because
variables must be declared in the process.
After having fixed the very obviously errors I get something to
simulate:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity sipo is
  port( serial_in, clock, reset: in std_logic;
end sipo;
architecture device of sipo is
signal rdy : std_logic := '0';
begin
    variable i: integer range 0 to 15 := 0;
    begin
          rdy <= '0';
        end if;
      end if;
      if(rdy /= '1' and rising = 4) then
        rising := 0;
        if(i = 15) then
30
          rdy <= '1';
31
          i := 0;
32
        else
33
          i := i + 1;
34
        end if;
35
      end if;
36
    end process main;
37
38
39
40
So having fixed most of the "problems" the simulation looks nearly fine
at first sight, but from the synthesizer you will get a error like:
ERROR:Xst:1534 - Sequential logic for node <rdy> appears to be
controlled by multiple clocks.
And this is due to trying to write to "rdy" from a hidden combinatorial
loop and from a synchronous reset.
So to sum up the two days: you cannot learn VHDL without pressing the
"simulate" or at least the "synthesize" button now and then. And without
having a look for the resulting messages...
BTW: pls use the [vhdl ] tags instead of the [c ] tags.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
