variable Component name
Guest #6118874
Hello
I'm trying to use a component and part of my code is:
for i in 0 to n-1 loop
for o in 0 to n-1 loop
for p in 0 to n-1 loop
if (o-p = 32) then
bf(i): butterfly port map(s(o),s(p),w(0),g1(i);g1(i+1))
end if;
end loop;
end loop;
end loop;
but I can't set the name of component "bf(i)" and I can't set a static
name either, because it's going to make as much component as needed by
defining n by user.
So my question is how can I do this.
Appreciate your help.
Best Regards.
Arsalan
Guest #6119115
Why do you want to do this? During simulation/synthesis, each of your
n^3 component instances will be assigned an individual name
automatically. For example, something like bf_1_3_7, depending on the
tools. So just write bf for the name. There is no need for indexing the
instances in your code.
> defining n by user
Of course you know, that n must be fixed. It can be set during compile
time, but not later when the simulation is running or when the design is
on an FPGA or ASIC.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
