ModelSim memory allocation failure
Guest #6118634
Hi dear experts,
when simulating a fairly simple design, ModelSim Pro ME (Microsemi
Edition, 32-bit) memory usage steadily increases until it reaches 4GB
limit and it crashes there.
# ** Fatal: (vsim-4) ****** Memory allocation failure. *****
# Attempting to allocate 131072 bytes
# Please check your system for available memory and swap space.
# End time: 11:16:49 on Jan 24,2020, Elapsed time: 2:01:08
# Errors: 6, Warnings: 926
I am not sure whether this is a tool issue or if there is any memory
leak in the testbench. The same testbench was not causing any crashes on
Vivado simulator.
How would a memory leak in a testbench look like?
Is it normal for ModelSim's memory usage to steadily increase as
simulation time increases or are all the logged signals saved/buffered
in the wlf file constantly?
Guest #6118917
Yes. More simulation time (respectivly events) or more logged signals,
both will increase the memory usage.
I usually stop my simulations with the following construct:
    process
    begin
        wait for 1000 ms;
        report "Simulation end.";
        report "stop hard." severity failure;
        wait;
    end process;
> Vivado simulator.
Both simulators are diffrent. Running code in one of them means
unfortunately nothing for the other, IMO.
Duke
Guest #6119028
First: 4GB and 32 bit should ring a bell. You're simply running out of
address space.
To track down memory leaks, I'd recommend valgrind under Linux and a
cross check against the GHDL simulator, if it's VHDL.
Guest #6122015
But, the simulator must do some paging and should not exceed the hard
limits regarding RAM usage, right? Slowing down due to paging I would
understand, but constantly increasing RAM usage until crash looks
definitely like a memory leak...
> address space.
Unfortunately, it is not purely VHDL, migrating everything to Linux
would be pretty difficult, since Vendor-dependent BFM infrastructure is
used.
4GB & 32bit rings a bell! My question was whether it is a tool bug or
can someone create a memory leak at the testbench?
It occurs also with some other example designs, so it is likely that the
ModelSim Pro ME delivered within the Libero SoC 12.x has a bug.
Guest #6122175
If the same simulation work with vivado simulator than I would assume a
tool bug.
(But I think it is possible to generate testbenches which will burst the
simulator limits...)
Duke
Guest #6122212
Yes it can increase but not necessarily due to logged waveforms. I have
simulations done with ModelSim Microsemi edition which run for 24 h and
generated 9 GB of waveform data without using 9 GB of RAM.
Yes, it is possible to write buggy testbenches that create all sorts of
runtime problems. never had memory leaks before but some years ago it
was easy to have testbenches that produced segfaults in ModelSim.
Guest #6123373
> runtime problems.
Buggy testbenches, I understand, but a memory leak? Can you please give
a concrete example?
Is there dynamic memory allocation mechanism for VHDL testbenches?
Even if there is, we actually define all the variables/signals
statically.
Guest #6123396
Not sure if it helps but you may give it a try.
1. You can tell Modelsim to write simulation output into a file and to
limit the file size. Maybe then it does not hold all the data in RAM. On
the other hand I don't know what happens when the file size reaches 4 GB
for the 32-bit modelsim. I had the case that one simulation wrote a 100G
file without using file size limit, but I dont remember the modelsim
version.
vsim -wlfopt -wlf some_file_name.wlf -wlfslim 200000 -wlfdeleteonquit
testbench_name.vhd
-wlf <...> defines the file
-wlsflim limits the file size
-wlfdeleteonquit removes the file when closing modelsim
2. If the above doesn't help, try limiting the log by only logging
signals you really need. Instead of "log -r /*" (activated by default?),
add the interesting signals using "add wave some_vhdl_module/*".
#6124322
> a concrete example?
No, not any more. It is long time ago. As a VHDL beginner Modelsim
crashed quite often and I didn't understand how people can use such a
tool. Nowadays my code is not that bad anymore and Modelsim does not
crash anymore :-)
I think I never had a memory leak but I definitely had several occasions
where I got segmentation faults (illegal memory access, often a null
pointer or an index pointing outside the array...). Like you sad there
is no dynamic memory handling in VHDL and the strict typing in VHDL
avoids illegal index but still I had segmentation faults during
runtime...
Guest #6846411
In case it helps anyone else, I found this in my UUT:
for (int i = 1023; i >= 0; i++) begin
    // do stuff
end
The astute observer will notice that I had i++ where I should have had
i-- => Infinite loop
Guest #6846644
Lothar M. wrote:
> Pls start a NEW thread for a NEW question!
> And in addition: ask a question! What is the problem?
Seems Jim Strieter is the initial FPGA guy and just wants to tell us
what went wrong in his example. No need to shout.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
