I2C inout port signal VHDL simulation
Guest #6117262
Hello there;
I have simulated a module with an external temperature sensor(LM75). In
the top Level module the port were defined as "inout" type something
like this
      i2c_scl    : inout std_logic;
      i2c_sda    : inout std_logic;
    achitecture behav of top_level is
    Signal i2c_scl_int    : std_logic;
    Signal i2c_sda_int    : std_logic;
begin
    i2c_scl <= '0' when i2c_scl_int ='0' else 'Z';
    i2c_sda <= '0' when i2c_sda_int ='0' else 'Z';
end;
With the above Code my Output was "ZZ" every time and I have to modify
the LM75 source Code as well as the i2c Controller Code to get a proper
Output Signal.
I would like to know if there is any other Approach by not modifying the
source Code and only add some Code in the testbench?
Thank you.
Guest #6123279
Hello Lothar;
Thanks for your help. I do have a proper Output Signal now.
The Problem I am facing now is my i2c_sda Signal. It will start showing
a proper waveform and later on just Change to "X" and some "H" and "0"
and the waveform will get back to normal after some time.
Is there any way I can filter it to have a clean Signal?
many thanks
Moderator (Company: Titel) #6123307
In real life you will have a proper signal.
To get rid of the 'X' in simulation you should initialise your signals
in a way like that:
    Signal i2c_scl_int    : std_logic := '1';
    Signal i2c_sda_int    : std_logic := '1';
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
