Debounce Code Correction for a Decimal Counter Project in 1Hz counting Speed
OP #6111794
I am completly new for the FPGA and basys3 development board. I have a
project for Counter on the 7 segment displays on the board. We got 3
different layers as a design.
cntr  cntr_rtl  cntr_top  cntr_top_struc  io_ctrl  io_ctrl_rtl
And in the project it has to diplay on the 7 segment controlled by the
switches : count up/count down  hold  reset options:
The priorities for these switches are:
reset
hold
count direction
top level VHDL file cntr_top.vhd
Port Name Direction Description
clk_i In System clock (100 MHz)
reset_i In Asynchronous high active reset
sw_i(15:0) In 16 switches
pb_i(3:0) In 4 buttons
ss_o(7:0) Out Contain the value for all 7-segment digits
ss_sel_o(3:0) Out Select a 7-segment digit
io_ctrl clk_i In System clock (100 MHz)
cntr0_i(n:0) In Digit 0 (from internal logic)
cntr1_i(n:0) In Digit 1 (from internal logic)
cntr2_i(n:0) In Digit 2 (from internal logic)
cntr3_i(n:0) In Digit 3 (from internal logic)
sw_i(15:0) In 16 switches (from FPGA board)
pb_i(3:0) In 4 buttons (from FPGA board)
ss_o(7:0) Out to 7-segment displays of the FPGA board
ss_sel_o(3:0) Out Selection of a 7-segment digit
swclean_o(15:0) Out 16 switches (to internal logic)
pbclean_o(3:0) Out 4 buttons (to internal logic)
cntr.vhd
cntrup_i In Counts up if signal is ‘1’
cntrdown_i In Counts down if signal is ‘1’
cntrreset_i In Sets counter to 0x0 if signal is ‘1’
cntrhold_i In Holds count value if signal is ‘1’
cntr0_o(n:0) Out Digit 0 (from internal logic)
cntr1_o(n:0) Out Digit 1 (from internal logic)
cntr2_o(n:0) Out Digit 2 (from internal logic)
cntr3_o(n:0) Out Digit 3 (from internal logic)
I will attach also the file to the attachment. Now my code is working
and do all the funcitionality correct but there is only one issue which
is the DEBOUNCE code part.
I didnt use the clk signal for the code and i have to change it. The
certain given clock signal has to be used.
So can any be give me suggestions how i can correct the debounce concept
in the code.
Please waiting for your suggestions.
Any help would be great appricated thanks for all.
here down below example for debounce but couldnt find to way to
implement.
-- Debounce buttons and switches
p_debounce: process (clk_i, reset_i)
begin -- process debounce
if reset_i = '1' then -- asynchronous reset (active high)
elsif clk_i'event and clk_i = '1' then -- rising clock edge
end if;
end process p_debounce;
swsync_o <= swsync;
pbsync_o <= pbsync;
Moderator (Company: Titel)
Nice job for basic hardware design.
That is only an empty template with absolutely nothing in it.
> but couldnt find to way to implement.
How would you implement such a debouncing in real hardware with
flipflops and counters and logic? When you have an idea, then simply
describe it with the hardware description language VHDL.
You can have a look how others do it: see the data sheet of the MAX6818.
Understand, what the device is doing! When you understand, what the
device is doing, its kind of simple to implement that function in VHDL:
http://www.lothar-miller.de/s9y/archives/4-Tasterentprellung-wie-MAX6816.html
> We got 3 different layers as a design.
Crude and chatty academic style.
Not a nice job to be forced to solve easy problems that cumbersome way.
Pls use the [vhdl] tags as described above each text box...
Guest
Here is the my code for debounce.
My tutor told me that i need to do it with the clock which it is already
been for the system.
But my code uses some sort of extra generated signal so i need to change
the implementation of the lines down below according to the empty
skript.
-- Generate 1 KHz enable signal.
p_slowen: process (clk_i, reset_i)
begin
  s_enctr <= (others => '0');
  s_2khzen <= '0';
  if s_enctr = COUNTVALUE then  -- When the terminal counter is reached, set the release flag and reset the counter
    s_2khzen <= '1';
    s_2khzcount <= std_logic_vector(to_unsigned(to_integer(unsigned( s_2khzcount )) + 1, 4));
  else
    s_enctr <= std_logic_vector(to_unsigned(to_integer(unsigned( s_enctr )) + 1, 17)); -- As long as the terminal count is not reached: increment the counter.
    if  s_2khzen = '1' then
    s_2khzen <= '0';
    end if;
    end if;
  if s_2khzcount = "1010" then
    s_1hzen <= not s_1hzen;
    s_2khzcount <= "0000";
  end if;
end if;
end process p_slowen;
30
31
32
33
34
p_debounce: process (s_1hzen, reset_i)
35
variable dbouncecntr : integer:=0;
36
begin
37
38
    swdebounced <= "0000000000000000";
39
    pbdebounced <= "0000";
40
    dbouncecntr :=0;                 -- Change clocking the process with signal from sens list.
41
else
42
    if (dbouncecntr = 0) then
43
                swtmp <= swsync1;
44
                pbtmp <= pbsync1;
45
                dbouncecntr := dbouncecntr + 1;
46
    elsif (dbouncecntr = 1) then
47
                if (swtmp = swsync1) then
48
                    swdebounced <= swsync1;
49
                end if;
50
                if (pbtmp = pbsync1) then
51
                    pbdebounced <= pbsync1;
52
                end if;
53
                dbouncecntr := 0;
54
55
    end if;
56
   end if;
57
58
swclean_o <= swdebounced;
59
pbclean_o <= pbdebounced;
You can also check the hole files that i upload for the vhdl folder.
Congratulation: you formed a combinatorial loop.
 begin
 else
        dbouncecntr := dbouncecntr + 1; ---- here it is: a counter with no clock!
I would write your REALLY BIG enable process somehow that way by using
integer as counters:
p_slowen: process (clk_i, reset_i) -- can't see no need for the reset...
begin
  s_2khzen <= '0';                   -- the default value is '0' but it
  s_1hzen  <= '0';                   -- maybe overwritten furtherdown
  if s_enctr < COUNTVALUE then       --  COUNTVALUE = (f_clk_i/2kHz)-1
    s_enctr <= s_enctr + 1;
  else
    s_enctr <= 0;
    s_2khzen <= '1';                 -- 2kHz clock enable
    if s_2khzcount<1999 then
       s_2khzcount <= s_2khzcount+1;
    else
       s_1hzen <= '1';               -- 1Hz clock enable
    end if;
  end if;
end if;
While editing I was heavily wondering, what the s_2khzen is for.
But I would use it for debouncing:
p_debounce: process (clk_i, reset_i) -- USE OLNY ONE AND THE SAME CLOCK IN THE WHOLE DESIGN
                                     -- again absolutely no need for the reset....
variable cntpb, cntsw : integer range 0 to 15 := 0;
begin
       -- debounce sw
       if swsync1 /= swdebounced then
          cntsw<=0;
       else
          cntsw <= cntsw+1;
       end if;
       if cntsw = 15 then
      end if;
      --- same for pd
   end if;
end process;
I can't open rar files here. Why not simply attaching the VHDL flies
plus getting a bonus like sytax higlighting?
BTW: check the use of the vhdl tags...
    Post long source code as attachment, not in the text
    [vhdl]VHDL code[/vhdl]
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
