LVDS input output behaviour
Guest #6101154
I interfaced FPGA(Kintex_7, LVDS_25, Vadj=1.8v)with external board to
provide inputs(Analog voltage and reference voltage) to LVDS. I adjusted
frequencies of signal generators  to 1µHz and amplitudes to least
possible value 10mv.  When both the inputs are 10mv, comparator output
is zero. I kept analog voltage 10mv and increased reference
voltage(51mv) till the comparator turn on. In the next step, reference
voltage is kept same and analog voltage is increased till comparator
turn on. This process is repeated to max voltage levels.    Please find
the attached file for the values noted down. I’m unable to relate this
to theory. Analog voltage is always less than Reference voltage but
still why the comparator keeps switching? In the beginning its 41mv
difference but later it will be 100mv, 250mv …why so?. It would be
helpful if someone explain the LVDS input output behavior as a
comparator considering those noted values in the file.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
