Output undefined
OP #6100096
Hi, I have a problem with Active HDL.
So I was given a 5 variable function with truth table.
I need to implement it on 4to1 mux and 2AND elements.
When I test only the mux it works perfectly, but when I combine it with
other mux and 2AND gate it doesn`t work..
Here is the code of mux:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.std_logic_unsigned.all;
entity mux_4_to_1 is
   port(
     E : in STD_LOGIC;
     D : in STD_LOGIC_VECTOR(15 downto 0);
     A : in STD_LOGIC_VECTOR(3 downto 0);
     F : out STD_LOGIC
end mux_4_to_1;
architecture mux of mux_4_to_1 is
begin
  process (E)
  begin
  if E = '1' then
  F <= D(Conv_Integer(A));
  end if;
  end process;
end mux;
And the mux`s combined code generated by Active HDL from my block
diagram:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_signed.all;
entity scheme is
  port(
       a : in STD_LOGIC;
       b : in STD_LOGIC;
       c : in STD_LOGIC;
       d : in STD_LOGIC;
       e : in STD_LOGIC;
       Data : in STD_LOGIC_VECTOR(15 downto 0);
       Data_1 : in STD_LOGIC_VECTOR(15 downto 0);
       f : out STD_LOGIC
end scheme;
architecture scheme of scheme is
component mux_4_to_1
  port (
       E : in STD_LOGIC;
       F : out STD_LOGIC
30
end component;
31
32
---- Signal declarations used on the diagram ----
33
34
signal NET336 : STD_LOGIC;
35
signal NET345 : STD_LOGIC;
36
signal NET431 : STD_LOGIC;
37
38
begin
39
40
U1 : mux_4_to_1
41
  port map(
42
       A(0) => d,
43
       A(1) => c,
44
       A(2) => b,
45
       A(3) => a,
46
       D => Data,
47
       E => NET431,
48
       F => NET336
49
50
51
U2 : mux_4_to_1
52
  port map(
53
       A(0) => d,
54
       A(1) => c,
55
       A(2) => b,
56
       A(3) => a,
57
       D => Data_1,
58
       E => e,
59
       F => NET345
60
61
62
f <= NET345 or NET336;
63
64
NET431 <= not(e);
65
66
67
end scheme;
Also I include screenshots of block diagram and waveform.
Thanks on advance for your help!
And sorry if question is stupid.
Moderator (Company: Titel) #6100144
Indeed? Strange...
Using both the unsigned an signed math libs will bring the synthesizer
into trouble when encountering an arithmetic operation. Additionally in
that module neither of the three math libs is needed at all!
> but when I combine it with other mux and 2AND gate it doesn`t work..
What do you expect and what do you get instead? And how do you see that?
What can we see there? And what should be instead of that?
  if E = '1' then
  end if;
Thats very bad coding style: because you don't have a default value for
F or an "else" assigning a value to F you will get a latch. A latch
alone is bad enough, but a accidently latch is much worse!
Think about the previous lament about latches and have a close look to
this OR gate.
And then try that:
  if E = '1' then
  else
     F <= '0';
  end if;
or that:
  F <= '0';
  if E = '1' then
  end if;
And to get the "force-simulation-orgy" working complete the sensitivity
list of the process:
  process (E,A,D)
Because the sensitivity list MUST include every signal that may alter
the output/result of the process.
Really? ... With that incomplete sensitivity list? ... Strange!
Moderator (Company: Titel) #6100271
Just to twist the fingers a little i setup a testbench and simulated the
design with a complete (e,a,d) an the incomplete (e) sensitivity list
like that:
begin
  process (E,a,d) -- complete sensitivity list
  begin
    F <= '0';   -- default value
    if E = '1' then
    end if;
Additionaly I added a screenshot with the correct senitivity list, but
no default value for f.
And for all of the screenshots I added the testbench. Its much easier
and protable(!!) than twiddling around with that force-thing in the
simulator.
Moderator (Company: Titel) #6100279
To finish up, I did a simulation of the mux itself also. I setup a
simple testbench for the 4-1 mux and simulated the original "perfectly
working" code.
As I expected, this code does not do what it should due to the
incomplete sensitivity list. And the E input does not do what it should
do due to the missing default value.
With the correct code the mux works really perfectly...  ;-)
OP #6100836
I appericate Your reply!
But when I changed the mux code it still doesn`t work..
Still the same problem
Here`s the code of mux i corrected as You said:
library IEEE;
   port(
     E : in STD_LOGIC;
     F : out STD_LOGIC
end mux_4_to_1;
begin
  process (E, A, D)
  begin
  F <= '0';
  if E = '1' then
  end if;
  end process;
end mux;
And the device code generated by active hdl, and by the way, when I
remove those not needed libraries and hit compile they comeback, don`t
know why, compiler adds them by itself..
library IEEE;
entity schm is
  port(
       a : in STD_LOGIC;
       b : in STD_LOGIC;
       c : in STD_LOGIC;
       d : in STD_LOGIC;
       e : in STD_LOGIC;
       Data1 : in STD_LOGIC_VECTOR(15 downto 0);
       f : out STD_LOGIC
end schm;
architecture schm of schm is
---- Component declarations -----
  port (
       E : in STD_LOGIC;
30
       F : out STD_LOGIC
31
32
end component;
33
34
35
36
signal NET114 : STD_LOGIC;
37
signal NET124 : STD_LOGIC;
38
signal NET133 : STD_LOGIC;
39
40
begin
41
42
----  Component instantiations  ----
43
44
U2 : mux_4_to_1
45
  port map(
46
       A(0) => d,
47
       A(1) => c,
48
       A(2) => b,
49
       A(3) => a,
50
       D => Data,
51
       E => NET114,
52
       F => NET124
53
54
55
U3 : mux_4_to_1
56
  port map(
57
       A(0) => d,
58
       A(1) => c,
59
       A(2) => b,
60
       A(3) => a,
61
       D => Data1,
62
       E => e,
63
       F => NET133
64
65
66
NET114 <= not(e);
67
68
f <= NET133 or NET124;
69
70
71
end schm;
Those lines aren`t working:
       F => NET133
       F => NET124
Thanks!
Moderator (Company: Titel) #6101487
Can't see no problem there. Those are just signal assignments. Theres no
funcionality at all.
I took your code and my testbench and did therein some changes with
some letters and underlines and put them both together in the simulator
and found out: its working fine on Xilinx ISIM. I'm absolutely sure its
working on Aldec also, but my license ended, I must get a new one to
prove it  ;-)
> when I remove those not needed libraries and hit compile they comeback,
> don`t know why, compiler adds them by itself..
Its compiled out of that schematic. As a lucky guy I don't use any
graphic editor in any toolchain. And I don't use that signal forcing in
simulation either. Just plain VHDL from top to bottom. It can all I
need. Obviously that way I encounter less problems.
And thats what I urge you: forget those graphical interfaces, write the
testbench and the interconnect in VHDL.
BTW:
Pls post screenshots as png files. They don't have any artifacts and are
clearly readable.
https://en.wikipedia.org/wiki/Compression_artifact
BTW2:
       A(0) => d,
       A(1) => c,
       A(2) => b,
       A(3) => a,
Thats a really strange bit order. You get a knot in the brain twiddling
it out.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
