High signal for two clock cicles
OP #6070930
Good morning, I'm tring to write a code able to raise up the output
signal (called Input_err_ASCII) to '1' logic level. I tried using a
Counter, but it doesn't work very well.
Follow a part of my code :
My_clk_counter : Counter
    generic map (Nbit => Nbit)
    port map (
      input => "00000001",
      clk => clk,
      resetn => Counter_ON,
      output => cicli_clk
Counter_ON <= '1' when (unsigned(Msg_in)<97 or unsigned(cicli_clk)>2);
Input_err_ASCII <= '1' when (unsigned(Msg_in)<97 and
unsigned(cicli_clk)<2) else '0';
Counter_on : is a signal able to activate the Counter
Cicli_clk : is the counter's output
I need your help, please.
Guest
Well, this is a little bit unspecific, isn't it?
What did you expect from your design, and how does it behave instead?
Did you do any simulation, and what is the result? Did you check if the
counter works correctly?
With the information you provided it is impossible to help you. This may
be the reason why nobody is answering your question.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
