More actuals found than formals in port map ERROR
OP (Company: Student) #6058227
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Fullsubtractor is
    Port ( X : in  STD_LOGIC;
           Y : in  STD_LOGIC;
           Z : in  STD_LOGIC;
           D : out  STD_LOGIC;
           B : out  STD_LOGIC);
end Fullsubtractor;
architecture Behavioral of Fullsubtractor is
signal t: STD_LOGIC_VECTOR(7 downto 0);
Component ThreeToEightDecoder
Port( X,Y,Z: IN STD_LOGIC;
      D: OUT STD_LOGIC_VECTOR(7 downto 0));
End Component;
begin
Stage1 : ThreeToEightDecoder Port
Map(X,Y,Z,t(0),t(1),t(2),t(3),t(4),t(5),t(6),t(7));
D<=(t(4) or t(2) or t(1) or t(7));
B<=(t(3) or t(5) or t(2));
end Behavioral;
I have "More actuals found than formals in port map" error and I can't
realize why.
Moderator (Company: Titel)
> realize why.
The component ThreeToEightDecoder has 4 ports (3 input ports 1 bit
wide, and 1 output port 8 bits wide).
You try to connnect 11 1-bit signals to those 4 ports. A slight
mismatch.
This would match:
Stage1 : ThreeToEightDecoder Port Map(X,Y,Z,t);
I suggest to use explicit assignment, then such simple things won't
happen any more.
Stage1 : ThreeToEightDecoder Port Map(X>X,Y->,Z-Z,D->t);
BTW:
What do you want to do with this strange bit order in the wrong port
list: t(0),t(1),t(2),t(3),t(4),t(5),t(6),t(7)?
Do you want to flip bits 0->7, 1->6,..., 7->0?
Isn't this:
mean;
 (input0,input1,input2,output1,output2,output3,output4,output5,output6,ou
tput7,output8);
I solved my problem.Thanks for help.Correct code as this:
library IEEE;
           Y : in  STD_LOGIC;
           Z : in  STD_LOGIC;
           D : out  STD_LOGIC;
           B : out  STD_LOGIC);
end Fullsubtractor;
    Port( X: IN STD_LOGIC;
         Y: IN STD_LOGIC;
       Z: IN STD_LOGIC;
End Component;
begin
Stage1 : ThreeToEightDecoder Port Map(X,Y,Z,t(7 downto 0));
end Behavioral;
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
