calculate power of float number
Guest #6057245
I try to calculate y=2.5^x. y([0,2048)) is output which is 11 bits
positive int and x([0,8)) is 6 bit which will fixed-point with 3 digits
decimal and 3 digits fractional.
I write this module;
module prime(
    input [5:0] x,
    output [10:0] y
    assign y = ((5'b11001)/(4'b1010))**( x / (10'b1111101000));
endmodule
RTL scheme : https://hizliresim.com/1ploYN
But it did not work. Also, I upload RTL scheme, x is not attached.
What is the reason for this? Could not verilog make a calculation with
float numbers with this method?
Guest
Simply use a look-up table. Your 6 input bits result in 64 combinations,
which you can easily write down.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
