Using a BFM in system verilog code
Guest #6041710
Hi all,
I am new to system Verilog and learning to write a test bench for
already existing code.
I have a master.sv file which has the code for SPI master. I have
written a basic testbench
(master_tb.sv)to test the master, but to simulate the SPI bus I wanted
to use a verification IP already provided by sysWip(http://syswip.com).
The VIP has an interface file and a package file.
How do I use it in my code?
where do I instantiate the interface, start the spi environment and the
connection?
do I need to change anything in my master.sv file?
my master.sv file is given below
module master
    input clk,
    output sdi,
    input sdo,
    output sclk,
    output [2:0] slave_select
i have just typed the code for the test bench.
module master_tb();
wire sclk;
reg clk;
reg sdo;
wire sdi;
wire [2:0] slave_select;
master_tb dut(
     .sclk(sclk),
     .sdo(sdo),
and so on
where do i do the import of the interface?
do i need master interface too? or just the slave interfcae is needed to
test my code?
Is there any simple sample code availbale?
Guest
You should look into the example testbench provided with the VIP,
everything is shown there. First, try to simulate their example.
> test my code?
That depends on the type of your own SPI controller model: Is it a
master or a slave?
You did not spend so much time in reading the documentation, did you?
There is an examples folder which contains the sample code you are
searching for.
However, you should yourself make familiar with the concepts of
interfaces and class based verification, these are some of the most
important and advanced concepts in SystemVerilog.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
