VHDL write to specific memory address
OP #5941216
Hello,
currently I am trying to buffer a value from VHDL and read it out in
C++. To give you a better understanding of my situation:
I want to use the internal clock of my FPGA, to be used by C++. I use a
Xilinx FPGA with a linux os, so I can run my C++ software. The hardware
was predesigned.
My idea was to read out the clock signal with VHDL and buffer it by
writing into the memory (on a hardcoded address), so I can read it out
with C++.
But I have issues writing to a very specific address.
Is this even possible with VHDL (or Verilog) or do I have to work
completely in C++ for my issue?
PS: I know there are examples out there, talking about the issue of
saving data in the memory, but they do not write into a specific memory
address.
Best Whishes
Robert
Guest
No. Linux is not running on an FPGA. I guess you have a Zynq device and
Linux is running on the embedded CPU cores, right? Or you have a
softcore CPU? Which one?
> with C++.
A clock is typically a signal toggling each some nanoseconds. You want a
memory location where a certain bit is changed some million times per
second, and read this memory location with a software running on a
non-realtime OS? Possibly you want something different, namely
synchronize a software process to a clock signal generated inside the
FPGA?
But to answer your question: No, you cannot use VHDL to write data into
a memory location. But you can use VHDL to specify an architecture that
does it. This is quite common. You can access the Zynq memory via the
internal AXI bus from the programmable logic.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
