N samples from an ADC
OP (Company: California Institute of Tech) #5923254
Hi there,
I'm embarking on a project to develop a measurement system, as well as
basic FPGA configuration skills. It was new to me 4 weeks ago, but I'm
beginning to pick up the intuition.
My overarching goal is
-to collect a N-sample length of data
-perform some digital processing on that data
-store a final value
-repeat and average
Currently, I am deciding how I will collect each set of N samples from
an on board 16-bit ADC.
I get 5 samples at a time, and I would like to accumulate them into an
array so I can easily index into it for
mean-subtraction/demodulation/FIR-filtering purposes.
I have been reading about in-chip RAM, on board SRAM, and also the
concept of FIFO devices.
Would a FIFO module be able to buffer N=1000+ samples into a single
array?
I was beginning to write something using unpacked SystemVerilog arrays,
but I had a feeling that they would not synthesize into something pretty
or optimal. Is there a standard way to approach this, Advanced Thanks!
Moderator (Company: Titel)
If possible: use the RAM blocks inside the FPGA. They're big enough and
its by far the most easy way.
> to buffer N=1000+ samples into a single array
Make the buffer size a power of 2 eg. 1024, 2048..., then handling of
the fifo pointers is incredibly simple.
> they would not synthesize into something pretty or optimal.
Read the synthesizer manual how to describe the RAM to get it fit into
the RAM blocks. Otherwise you will get some strange kind of memory. In
the worst case the synthesizer must spend a lot of function blocks with
their flipflops for storing.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
