JLCPCB - 4 Layers Minimum Design Rules
OP #5922525
Dear community,
has anyone fabricated a 4Layer PCB with JLCPCB? On their website
(https://jlcpcb.com/capabilities/Capabilities), they say that the
*minimum trace-width is 3.5mil
*minimum trace-to-trace distance is 3.5mil
Unfortunately, JLCPCB rejected my PCB and replied as followed:
Hello Sir ,
Many thanks for your order . But sorry to bother you .
As the picture ,we found the trace width and trace clearance is only 0.089mm ,and the spacing between traces is too small ,we need Min.0.25mm spacing .
Below are some information.
The minimum via diameter : 0.45mm
The Min drill hole :Min. 0.3mm for 2-layer board ,Min. 0.2mm for 4-layer/6layer board
Trace width and trace clearance :Min. 0.1mm
Thanks!
Marcel
The spacing from trace to through pads : Min 0.127MM
The spacing from hole to trace :Min. 0.25mm
The spacing from hole to hole :Min. 0.25mm
These specs differ greatly from the official ones, right? Firstly, a
100um trace width corresponds to 3.9mil and not 3.5mil as opposed to
their website. Secondly, a trace-to-trace spacing of 0.25 (I assume they
measure from mid trace to mid trace) is also significantly larger.
Anyone have/had similar problems with JLCPCB, so far?
Guest #5922827
Many manufacturers have different classes and different prices for them
- smaller design rules result in higher prices. May be you ordered PCBs
with 0.25 mm spacing and you could also have 3,5 mil spacing, but for a
substantially higher price.
But the correct answer you can only get from the manufacturer himself.
Georg
Guest #6042996
For a prototype I needed a 6 layer PCB (with a BGA 0.8mm on it) and
decided to give JLC a try (in the past I ordered several 2L-designs and
was satisfied with the quality).
They accepted my design (4 mil spacing), but when I got the boards I
first realised that all the thermals on the pads were removed.
After further investigation it seems that they just increased the
isolation distance to about 8 mil?
Some ground plane connections on the top and bottom layer are now
missing, I think I don't want to know what how they messed up the inner
layers.
I filed a complaint and got the answer that the minimum gap is 10 mil.
Actually, this is not what they write on the website.
Conclusion:
Good for simple 2L-boards,
crap for designs with tight tolerances.
And dont't trust the specs on the website!
Alex
Guest #6043019
Marcel R. wrote:
> I assume they measure from mid trace to mid trace)
I would not agree. Distance is from copper to copper in my opinion. We
really need to see the picture.
I ordered already 4 layer PCBs from JLCPCB at the edge of their
specifications without any problem.
Guest #6043152
Had just a couple of months ago a design with 3.5mil tracks and 3.5mil
spacing.
The only thing which they didn't like was less than 3.5mil spacing to a
plated through-hole. But they changed the restring of the hole.
It was a 4-layer board.
Everyting worked fine and they didn't complain further.
Guest #6043989
My design passed their checks without any error,
they charged for a 3.5mil design,
and still they say the min. clearance is 10 mil...
Alex
Start a new thread
