clocking module in vivado?
OP #5919491
Quite often I see such piece of code on the github repositories. I
wonder how such code is generated in vivado - i mean, is there any
ready-to-use graphical library that generates such code? Many projects
contains only vhdl files (without any blocks design).
It looks like a template that was generated by some tool or library.
example below:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library UNISIM;
use UNISIM.VComponents.all;
entity clocking is
    Port ( clk100MHz : in STD_LOGIC;
           clk125MHz : out STD_LOGIC;
           clk125MHz90 : out STD_LOGIC);
end clocking;
architecture Behavioral of clocking is
    signal clk100MHz_buffered     : std_logic := '0';
    signal clkfb                  : std_logic := '0';
    signal clk125MHz_unbuffered   : STD_LOGIC;
    signal clk125MHz90_unbuffered : STD_LOGIC;
begin
bufg_100: BUFG
    port map (
        i => clk100MHz,
        o => clk100MHz_buffered
   -- Generate a 125MHz clock from the 100MHz
   -- system clock
pll_clocking : PLLE2_BASE
   generic map (
30
      BANDWIDTH          => "OPTIMIZED",
31
      CLKFBOUT_MULT      => 10,
32
      CLKFBOUT_PHASE     => 0.0,
33
      CLKIN1_PERIOD      => 10.0,
34
35
      -- CLKOUT0_DIVIDE - CLKOUT5_DIVIDE: Divide amount for each CLKOUT (1-128)
36
      CLKOUT0_DIVIDE     => 8,  CLKOUT1_DIVIDE     => 20, CLKOUT2_DIVIDE      => 40,
37
      CLKOUT3_DIVIDE     => 8,  CLKOUT4_DIVIDE     => 16, CLKOUT5_DIVIDE      => 16,
38
39
      -- CLKOUT0_DUTY_CYCLE - CLKOUT5_DUTY_CYCLE: Duty cycle for each CLKOUT (0.001-0.999).
40
      CLKOUT0_DUTY_CYCLE => 0.5, CLKOUT1_DUTY_CYCLE => 0.5, CLKOUT2_DUTY_CYCLE => 0.5,
41
      CLKOUT3_DUTY_CYCLE => 0.5, CLKOUT4_DUTY_CYCLE => 0.5, CLKOUT5_DUTY_CYCLE => 0.5,
42
43
      -- CLKOUT0_PHASE - CLKOUT5_PHASE: Phase offset for each CLKOUT (-360.000-360.000).
44
      CLKOUT0_PHASE      =>    0.0, CLKOUT1_PHASE      => 0.0, CLKOUT2_PHASE      => 0.0,
45
      CLKOUT3_PHASE      => -270.0, CLKOUT4_PHASE      => 0.0, CLKOUT5_PHASE      => 0.0,
46
47
      DIVCLK_DIVIDE      => 1,
48
      REF_JITTER1        => 0.0,
49
      STARTUP_WAIT       => "FALSE"
50
51
   port map (
52
      CLKIN1   => CLK100MHz_buffered,
53
      CLKOUT0  => CLK125MHz_unbuffered,   CLKOUT1 => open,  CLKOUT2 => open,
54
      CLKOUT3  => CLK125MHz90_unbuffered, CLKOUT4 => open,  CLKOUT5 => open,
55
      LOCKED   => open,
56
      PWRDWN   => '0',
57
      RST      => '0',
58
      CLKFBOUT => clkfb,
59
      CLKFBIN  => clkfb
60
61
62
bufg_125Mhz: BUFG
63
    port map (
64
        i => clk125MHz_unbuffered,
65
        o => clk125MHz
66
67
68
bufg_125Mhz90: BUFG
69
    port map (
70
        i => clk125MHz90_unbuffered,
71
        o => clk125MHz90
72
73
74
end Behavioral;
Many thanks
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
