Write in a file with verilog
Guest #5918382
Hello, I'd like to write a value in a file. This is the code I have
implemented:
task speed;
    input [23:0] v;
    input [23:0] s;
    integer f;
      begin
          f = $fopen("test.txt","w");
              if (!f) begin
                $display("Could not open \"test.txt\"");
              end else begin
              #70000;
                for(int i=0; i<24; i++) begin
                  $fwrite(f,"%b", s[i]);
                end
              end
              #10000
          $fclose(f);
     end
  endtask
Unfortunately, what I read is "xxxxxxxxxxxxxxxxxxxxxxxx". I was thinking
that this happens since the date is not available when I try to write
it, so I put a delay, but it's not still working. Can anyone help me
please?
Guest #5918409
Put $display() inside the for loop to check if input data is defined
while writing to the file. Not sure if the delay in your code has any
effect if the input data is undefined at the point when the task is
called. Remember that a task is a pure software function that is
executed by the simulator at the time when it is called, not permanently
like an 'always' construct.
Guest #5918410
I think the problem is not in the code you have showed us.
Also long as your  "input [23:0] s" is undefined you will get the 'x'es.
Duke
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
