I2C init error with the msp430f5529
OP #5866620
Hey there, I have tried to make a program which can give me the data
from my sensor SI7006-20A with I2C. The problem is, that when I run my
project, nothing happens. I also used an Logic Analyzer and I saw that
nothing happened. I really don't know what I could change. Maybe someone
could help me, thanks a lot!
#include "main.h"
#include "msp430f5529.h"
unsigned char add = 0x80; // serial number of the sensor
unsigned char RHMeasure = 0xE5;
unsigned char TEMpMeasure = 0xE0;
double temp, rh;
int help1, help2;
void initI2C(){
   UCB0CTL1 |= UCSWRST;
  UCB1CTL0 = (1<<UCMST)|(1<<UCMODE0)|(1<<UCMODE1)|(1<<UCSYNC);
  UCB1CTL1=(1<<UCSSEL1)|(1<<UCTR);
  UCB1BR0 = 200;
  UCB1BR1 = 0;
UCB1I2CSA = (add>>1);
UCB1CTL1 &= ~(1<<UCSWRST);
void sendDataI2C(unsigned char data){
   UCB1CTL1|= (1<<UCTXSTT);
   UCB1TXBUF = data;
   while(UCB1IFG&(1<<UCTXIFG)==0x00);
   UCB1CTL1 |= (1<<UCB1IFG);
30
unsigned char readDataI2C(){
31
32
33
34
35
36
unsigned int startRead(){
37
  unsigned int data=0;
38
    UCB1CTL1&=~(0x10);
39
    UCB1CTL1 |=(1<<UCTXSTT);
40
  //  while(UCB1CTL1 &(1<<UCTXSTT));
41
    if(UCB1CTL1 &(1<<UCTXSTT)){
42
      P1DIR |= BIT0;
43
      P1OUT |= BIT0;
44
    }else{
45
      P4DIR |= BIT7;
46
      P4OUT |= BIT7;
47
48
   // while(UCB1STAT&(1<<UCBBUSY) > 0x00);
49
    while(UCB1IFG&(1<<UCRXIFG)==0x00);
50
    data = UCB1RXBUF*256;
51
52
53
    data += UCB1RXBUF;
54
55
56
    UCB1CTL1 |= (1<<UCTXNACK);
57
    UCB1CTL1 |= (1<<UCTXSTP);
58
59
60
61
62
63
void startWrite(unsigned char cmd){
64
  UCB1CTL1|=(1<<UCTXSTT)|(0x10);
65
  //UCB1CTL1 |= (1<<UCTXSTP);
66
  UCB1TXBUF = cmd;
67
68
69
70
71
72
73
int main(){
74
    WDTCTL = WDTPW + WDTHOLD;
75
    P4DIR |= BIT2;
76
    P4DIR |= BIT1;
77
    initI2C();
78
    while(1){
79
80
81
    startWrite(RHMeasure);
82
83
    /* help2 = startRead();
84
    rh = (help2*125)/65536-6;
85
86
    startWrite(TEMpMeasure);
87
    help1 = startRead();
88
    temp = (help1*175.72)/65536-46.85;
89
90
    __delay_cycles(100);
91
92
93
Guest #5866634
Hi
translates to
UCB1CTL1=(1<<0x80)|(1<<0x10);
which leads to a warning.
Dont use avr-stylish shift operations. Use instead
UCB1CTL1 = UCSSEL1 | UCTR;
Take the compiler warnings serious.
Guest #5866939
The only functiopn that you call from main() is startWrite(). Can that
work without a prior call to initI2C()?
OP #5867008
I have the init above the while and I have just warnings of missing
return statement but I ignored this because i just want to check the
init. And it isn't working...
#include "main.h"
double temp, rh;
int help1, help2;
void initI2C(){
  UCB1CTL0 = UCMST | UCMODE0 | UCMODE1 | UCSYNC; //MasterMode   I2C Mode
  UCB1CTL1= UCSSEL1 | UCTR;
  UCB1BR0 = 200;                               //fSCL = SMCLK/(40+0*256)
  UCB1BR1 = 0;
UCB1CTL1 &= ~UCSWRST;
   UCB1CTL1|= UCTXSTT;
   UCB1TXBUF = data;
   while((UCB1IFG & UCTXIFG)==0x00);
   UCB1CTL1 |= UCB1IFG;
30
31
32
33
34
35
36
37
38
    UCB1CTL1 &=~ (0x10);
39
    UCB1CTL1 |= UCTXSTT;
40
  //  while(UCB1CTL1 & UCTXSTT);
41
    if(UCB1CTL1 & UCTXSTT){
42
      P1DIR |= BIT0;
43
      P1OUT |= BIT0;
44
    }else{
45
      P4DIR |= BIT7;
46
      P4OUT |= BIT7;
47
48
   // while((UCB1STAT & UCBBUSY) > 0x00);
49
    while((UCB1IFG & UCRXIFG) == 0x00);
50
51
    //ACK automatisch vermutlich
52
53
54
    data += UCB1RXBUF;
55
56
57
    UCB1CTL1 |= UCTXNACK;
58
    UCB1CTL1 |= UCTXSTP;
59
60
61
62
63
64
65
  UCB1CTL1 |= UCTXSTT | (0x10);
66
  //UCB1CTL1 |= UCTXSTP;
67
  UCB1TXBUF = cmd;
68
  while((UCB1IFG & UCTXIFG) == 0x00);
69
70
71
72
73
74
int main(){
75
76
    P4DIR |= BIT2;
77
    P4DIR |= BIT1;
78
79
80
81
    while(1){
82
83
    initI2C();
84
85
86
87
88
89
90
91
92
93
94
95
96
97
#5867156
This resets the wrong module; use UCB1CTL1.
This clears the reset bit, and the following baud rate setting is not
applied.
The 0x10 is the UCTXNACK bit. What's it doing here?
> UCB1TXBUF = cmd;
You can do that only after you have checked that the buffer is free
(TXIFG).
> P4DIR |= BIT2;
> P4DIR |= BIT1;
This sets these two pins as GPIO outputs. To connect these pins to the
I²C module instead, set the bits in P4SEL.
I would recommend to begin with a working example like
MSP430F55xx_uscib0_i2c_08.c.
Start a new thread
