Digital clock 7-seg display NEXYS-3
Guest #5850883
I have to do a project in VHDL on NEXYS3 Spartan6 FPGA board.
I tried many things but nothing actually worked for me. Could anyone
possibly help me and write the code how to make a digital clock based on
7 segment display?
It should display hours and minutes, contain 2 switches to increment
hours and minutes and have a diode ticking every seconds.
Id like to see as primitive code as its possible to understand easily.
Thanks for help
Moderator (Company: Titel)
Whoms homework is this?
Why don't you start with something and when you encounter a specific
problem then you ask for a hint.
Start with this task. Give your own try two evenings. At least...
Afterwards there's a super simple solution for a stop watch:
http://www.lothar-miller.de/s9y/archives/88-VHDL-vs.-Verilog-am-Beispiel-einer-Stoppuhr.html
It's fairly easy to understand and adapt to your job. Try Google
translate, it's German.
Guest
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity clockdigit is
port (clk1 : in std_logic;
      seconds : out std_logic_vector(5 downto 0);
      minutes : out std_logic_vector(5 downto 0);
      hours : out std_logic_vector(2 downto 0)
end clockdigit ;
architecture Behavioral of clockdigit  is
signal sec,min,hour : integer range 0 to 60;
signal count : integer :=1;
signal clk : std_logic :='0';
begin
process(clk1)
begin
if(clk1'event and clk1='1') then
count <=count+1;
if(count = 50000000) then
clk <= not clk;
count <=1;
end if;
end if;
30
end process;
31
32
process(clk)
33
begin
34
35
if(clk'event and clk='1') then
36
sec <= sec+ 1;
37
if(sec = 59) then
38
sec<=0;
39
min <= min + 1;
40
if(min = 59) then
41
hour <= hour + 1;
42
min <= 0;
43
if(hour = 23) then
44
hour <= 0;
45
end if;
46
end if;
47
end if;
48
end if;
49
50
end process;
51
52
end Behavioral;
I've done something like this, but I still dont know how to display it
on 7-seg display. Id like to display hours and minutes, and make a
ticking diode every second. Could you possibly help with the code?
It is NOT a proper way to generate clocks inside a FPGA. You will get a
warning for such a design style. Use clock-enable signals for that.
This is the well known "off-by-one" error. Not much of a problem here,
because it will get only 1/50000000 deviation for your clock. That means
your clock will be off by one second after almost a year due to that
error. But when you would do that to count milliseconds, then the
deviation would be a quarter of an hour...
Did you click on that link?
There you can see 1. how to use the numeric_std package and 2. how to
use clock enables and 3. how to get the digits to the display and 4.
that it is much better to count each of the 4 digits by its own, so it
can easily be displayed. Because with your code you encounter the
problem to fiddle the 4 digits out the hours and miuntes.
BTW:
Pls use the [vhdl] tags to wrap your code.
Guest
write your code more readable:
process(clk)
begin
 if rising_edge(clk) then
--add 'tick every second' condition here
  if sec = 59 then
   sec <= 0;
  else
   sec <= sec + 1;
  end if;
  if min = 59 then
   min <= 0;
  else
   min <= min + 1;
  end if;
  if hour = 23 then
   hour <= 0;
  else
   hour <= hour + 1;
  end if;
 --add closing end if of tick condition here
 end if;
end process;
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
