ws2812 vhdl problem
OP #5848954
Hi there,
I tried to run vhdl code from
https://github.com/trobanga/ws2812/blob/master/ws2812.vhdl
The strange thing is that timings are not met. As described in code, i
connect 50mhz clock to the ip block.
Can someone give me a hand with this and test vhdl code? Results
attached.
Many thanks,
FlatByte
Moderator (Company: Titel)
Flat B. wrote:
> i connect 50mhz
milli Hertz?
As far as I see the timing is exactly as to be expected.
350ns are not possible with 20ns granularity, therefore the term g_T0H *
CLOCK_FREQ / 1000 results in a time of 340ns. And the additional 40ns
are due to the state transitions wh and wl in the FSM, so you must get
340ns+20ns+800ns+20ns = 1180ns and 600ns+20ns+700ns+20ns = 1340ns with
this code.
What timing does a behavioural simulation show?
OP
Wow, many thanks for the great discussion. At last I've found right
place and right people for VHDL/FPGA discussion.
Lothar M. wrote:
> Flat B. wrote:
> > i connect 50mhz
> > milli Hertz?
Right. MHz.
> this code.
Wow. Thanks!
Lothar M. wrote:
> So that turns out the question: whats the actual problem?
As a "new" in VHDL/FPGA I was almost sure I did something wrong
implementing ws2812.vhdl file. I expected 800khz for driving WS2812B
leds.
Once again - many thanks! Your responses confirms that ws2812.vhdl
doesn't generate 800 KHz pulse.
PS. ws2812.vhdl file is not mine - I've just found it on the internet.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
