Variable clock with prescaler?
OP (Company: no) #5844195
I wanted to make a vco to get 8 different values of frequencies
dependent on controlfreq input and I made it successfully but for now I
want to add another single bit input so when its value is '1' I divide
each frequency of those by 1000 or in other words to get frequency by
hertz instead of kilo hertz .. here's my code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
entity VCO is
port (
controlfreq: in std_logic_vector(2 downto 0);
clock_out: out std_logic);
end VCO;
architecture bhv of VCO is
signal clk : std_logic;
signal div : std_logic_vector(7 downto 0):=(others=>'0');
begin
process(clk)
begin
if(clk'event and clk='1') then
div <= div + '1';
end if;
end process;
process(clk)
begin
if (controlfreq <= "000") then
clock_out <= div(0);
elsif (controlfreq <= "001") then
clock_out <= div(1);
30
elsif (controlfreq <= "010") then
31
clock_out <= div(2);
32
elsif (controlfreq <= "011") then
33
clock_out <= div(3);
34
elsif (controlfreq <= "100") then
35
clock_out <= div(4);
36
elsif (controlfreq <= "101") then
37
clock_out <= div(5);
38
elsif (controlfreq <= "110") then
39
clock_out <= div(6);
40
elsif (controlfreq <= "111") then
41
clock_out <= div(7);
42
end if;
43
end process;
44
45
end bhv;
Guest
I don't see a real question (mark) here.
If you need other frequencies than you need another prescaler.
Don't use this, use ieee.numeric_std.all instead with all proper type
definitions.
rising_edge(clk) is more reader friendly (and has some small advantages
in simulation).
I suggest to use the case-construct here. See:
https://en.wikibooks.org/wiki/Programmable_Logic/VHDL_Sequential_Statement
https://en.wikibooks.org/wiki/VHDL_for_FPGA_Design/Multiplexer
Duke
Moderator (Company: Titel)
Mohamed H. wrote:
> for now I want to add another single bit input so when its value is '1'
> I divide each frequency of those by 1000
You will need an additional prescaler here:
signal prescaler : integer range 0 to 999 := 0;
    if slowdown = '1' then  -- slowdown mode
        if prescaler = 999 then
           prescaler <= 0;
           div <= div + '1';
        else
           prescaler <= prescaler+1;
        end if;
    else                   -- traditional mode
        div <= div + '1';
    end if;
  end if;
Mohamed H. wrote:
> here's my code
Pls use the [vhdl] tags as described above every text input box.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
