Increase the frequency
Guest #5827644
hello everyone i try to increase the frequency of a VHDL code, I use
Quartus to minimize the worst-case Timing Peths, i found that the worst
is a block that calculates the minimum and à multiplexer.
I Wonder if ther is a way to describe thoses block to increase the
frequency without using the regesters. thank you . below the codes used:
Moderator (Company: Titel)
abdelhak taamouch wrote:
> i found that the worst is a block that calculates the minimum and à
> multiplexer.
Sounds like you are on the wrong path. This small code snippet itself is
implemented fairly fast.
So the question for absolute figures rises: what's the desired clock
frequency? And what do you  get?
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
