Dueprologic Cyclone iv fpga dev board
OP (Company: Mindteck) #5791872
I am using Cyclone iv ep4ce6e22c8n fpga development kit from
dueprologic.
When i try to flash the code it is taking more than 10 minutes to
complete the flashing.And i erased the fpga through quartus software
after that i am not able to flash the code and it is failing always.
Can you please answer to this question?
Regards
Hareesh
Guest #5791883
Hareesh M. wrote:
> Hi,
> dueprologic.
What question???
OP (Company: Mindteck) #5791889
John Doe wrote:
> Hareesh M. wrote:
>> Hi,
>> dueprologic.
> What question???
Hi jhon,
Thanks for your time
Why board is taking that much for flashing?
Why I am not able to flash after erasing
Many thanks
Hareesh
#5791932
You know, you're working with an FPGA?!? You are flashing a bitfile, not
"code". And you're not flashing the FPGA, instead you're flashing the
configuration memory. (which is a external device)
What configuration scheme do you use? JTAG, Flashloader, Bitbang
Adapter?!?
You must supply some information to us , so we can help.
OP (Company: Mindteck) #5791945
> Adapter?!?
I was trying active serial programming(.pof)file through usb
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
