Sending and receiving somme data within FPGA
OP (Company: University of Cergy Pontoise) #5755577
• ▲ useful
▼ not useful
Hello here,
I am working on FPGA virtex6 ML605, I have to write a program in (VHDL)
which allows to send and receive  some data within the same FPGA .
I don't  know to start it , please if someone can give me some steps ,
or document to helpe me
Like to explain me the global idea , thank !
Guest #5755662
• ▲ useful
▼ not useful
Well, this is your Hardware:
https://www.xilinx.com/content/xilinx/en/products/boards-and-kits/ek-v6-ml605-g/_jcr_content/mainParsys/xilinxtabs2/tab-hardware/xilinximage.img.gif/1505256007881.gif
So you got the following Interfaces which can send and receive:
UART, Ethernet, SFP, PCIe, USB, FMC, GPIO.
Now you have to decide which one you want to use.
Why do you have to to this? Is this for school?
This sounds strange. Should the data never leave the FPGA and just be
send by one part of the FPGA and received by another part of the FPGA? I
think you should somehow use an external interface.
At first you have to explain ab bit. Send and receive often involves two
or more devices, which is the other one? A computer? What do you already
know or what have you learned til now? Should you use a processor like
Mikroblaze inside the FPGA? If the is homewark, please post the full
deskription.
OP (Company: University of Cergy Pontoise) #5755710
• ▲ useful
▼ not useful
thank you for your reply .
I am working on a project of synchronization between two stations fpga,
to fully understand the function of the demo, my supervisor has asked
me:
-to send and receive data on the same card
-after between the two cards
and then I could go on to solve my synchronization problem.
I know a little about the theoretical things but the fact of putting it
into practice on the cards, that's point i have some difficult.
And i am using FMC110
Guest #5755736
• ▲ useful
▼ not useful
What do you mean with "Card"? The ML605 or the FMC110? Are you able to
send any data via the FMC110 Card? Here is the User Manual:
http://www.4dsp.com/pdf/FMC110_user_manual.pdf
Here is a diagram:
http://catalog.4dsp.com/content/diagrams/diagram_fmc110.png
If you want to send data with this FMC110 Card you "send" it as analog
wave via one or both DACs. The Datasheet for the DACs is this:
http://www.ti.com/lit/ds/symlink/dac5681.pdf
OP (Company: University of Cergy Pontoise) #5775584
• ▲ useful
▼ not useful
Hello here ;
I have  advanced a little on my project, I have realized a code that can
send an 8-bit data (serial transmission) but on receiving the data I
must perform a serial conversion to parralelle (8 bits).
At the level of sending my program is working well but at the reception
it does not work.
Now i don't know how can I add a control data_valide in my program and
do a serial conversion in parallel.
or if someone has suggestions to share me
  • [vhdl]VHDL-Code[/vhdl]
