Vhdl time window
OP #5723407
How is it possible in vhdl to implement a control in a time window
referred to a clock?
For example, define a time window that starts 4 ns before the clock and
ends 2 ns before the clock.
Or a window that starts 2 ns before the clock and ends 1 ns after the
clock.
Or a window that starts 2 ns after the clock and ends 5 ns after the
clock.
Then determine if in this time window a data line has remained stable
(no transitions).
Regards
Moderator (Company: Titel) #5723595
Usually such measurements are done by a high speed oscilloscope...
One way would be to implement a TDC (time to digital converter) and then
compare the both inputs (clock and signal) to check the phase of those
two signals.
But given those tight timings (1 ns range) you must consider the input
delay of a FPGA pad and later on the internal routing also. Because it
may be that the timing at the pin is totally correct, but inside the
FPGA there is a slack on the data line and at the actual flipflop it is
delayed by 3ns. Here you must work with timing constraints on the signal
line to be sure the routing is done properly.
BTW: to control a signal is totally different than simply measure or
to check a signal. Why do you need such a check?
OP #5723596
Tnx Lothar.
Sorry, i need check, not control.
But i need only a simulation vhdl code for this. Not a Real misure with
oscilloscope!
I need simulate a flop with T setup and T hold.
Case 1:  tsetup and thold  positive (  es 5ns, 1ns).
Case 2 : setup positive and thold negative.
Case 3: setup negative and hold positive.
I need to check in this temporals windows if a data is  stable.  Vhdl
code.
Guest #5723600
Moderator (Company: Titel) #5723615
Luca M. wrote:
> I need to check in this temporals windows if a data is  stable. Vhdl code.
One question more: do you have to implement that in real hardware for
real life signals or just simply for simulation?
If the first:
This cannot be done by "VHDL code" solely. You must have a very, very
close look at the particular datasheet of your particular FPGA and
figure out how you can implement a delay line for a TDC.
If the second:
Where does the input stimuli of your test bench come from? Do you
perform a timing simulation? If so: why? I didn't do that since the last
millenium. A proper synchronous design strategy together with proper
timing constraints gets your design running easily.
And all in all:
And for what? Is it a real application or just homework?
Guest #5724100
Example:
SETUP_TIME: Time before the rising edge of clk where data must be stable
HOLD_TIME: Time after the rising edge of clk  where data must be stable
Checker for Setup-Time:
tsu_checker: process
begin
  wait until rising_edge(clk);
  assert data'stable(SETUP_TIME) report "Setup violation!!" severity error;
end process;
Checker for Hold-Time:
thd_checker: process
begin
  wait until data'event;
  if clk = '1' then
    assert clk'stable(HOLD_TIME) report "Hold violation!!" severity error;
  end if;
end process;
This is only one of many possible ways to solve the problem
OP #5724468
For Shclumpf:
Right.. I need this!
But in your example the thold and setup are positive values.
I need check the violation if the thold is positive and tsetup is
negative also.
I need check the violation if the tsetup  is positive and thold is
negative also.
Guest #5724610
Another option is the keyword 'now'.
It represents the current simulation time.
You can store the timestamp of any event and calculate with the values.
Guest #5724684
If you understood the principle it should be easy for you to adapt the
examples to negative values.
Or use the keyword now.
If you have different cases dependent of positive or negative values you
can use the keyword 'if' :)
But anyway:
What is the sense of that all?
Du you want to simulate a backannotated design?
As Lothar said: it doesn't make sense..
OP #5724750
> But anyway:
Yes. With a model of complex flop i can simulate my fpga design to
ensure  set_output_delay is right.
Guest #5724769
If the design is synchronous or if the clocks of different domains are
in a fixed and known phase relation you can use constraints.
If there are asynchronous paths you can report and check the delay of
these paths after PaR.
There is no need to simulate.
And even if you simulate you have to make a simulation for all possible
phases between the clocks. And the number of these is infinite..
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
