Image sensor. high data rate
Guest #5702285
I'm trying to read Data from a Image sensor. My problem is, that the
sensor, is sending it data on 4 Output with 720Mbps. As far as I know,
typical microcontroller, example STM32F334R8, aren't fast enought to
receive the data. I have the possibility to save the raw data first and
work in a slower speed with the data later.
My question is, does anybody have an idea how to handle the high data
rate or know microcrontroller who, can handle the data rate.
kind regards,
Madcookie
Guest #5702326
matzetronics wrote:
> TI's OMAP Series of DSPs is designed to handle video and imaging quite
> fast:
> https://en.wikipedia.org/wiki/OMAP
That's not helpful and close to nonsense, really. Ever tried getting
your hands on OMAP 4 and above for industrial applications?
@TO: Please tell us more about the interface (MIPI, Parallel, ...?)
If it's MIPI, there aren't many viable options, the best luck you'd then
have with an FPGA solution. From experience I can tell that there are
many potential dead ends with MIPI capable processors, unless you're
playing in the consumer (>50k p.a.) league.
Guest #5702978
Thank you for the help,
It's send over 6 LVDS OUTPUT, 4 Data Output, 1 Clock Output and 1
synchronization LVDS, which send information, what currendly send over
the Data Output, for example:"New Line, New Frame,...".
Guest #5990366
Sometime has gone and i finished my project.
Here is a sort explanation for everyone with the same problem.
First thing is i changed the sensor to the  Python 1300 NOIP2SN1300A-QDI
with Parallel CMOS Output, which is slower.
For reading the Data and control the sensor I used the  CYUSB3KIT-003
EZ-USB board.  With the Cypress Board it's possible to send the data to
the PC and save them there .
However my System wasn't perfect, because sometimes i lost some Bytes
during transmission. Maybe with some change to the parameters from the
USB transmission or an algorithm to recover the lost byte, it might be
an useful setup.
Start a new thread
