vhdl code to find max value of stream of unsigned 8 bit values
OP #5688632
Describtion about the subject.
The unsigned values should be presented on an input vector(comnected to
slife switches S1-S8) and as soon as the read_in( connected to button
TA2) is pressed the value has read and checked if itis the maximum or
not. The maximum value should be given to LEDs( IN1-IN8) of the
out_max(connected to the button TA1) is pressed.
Guest #5688659
if rising_edge(clk) then
 if reset = '1' then
  max_value <= (others => '0');
 else
  if cur_val > max_value then
   max_value <= cur_value;
  end if;
 end if;
end if;
Moderator (Company: Titel) #5688808
This obviously is some kind of homework. Your teacher wants you to do
something and learn by doing that. We should not override this
intention. So let's try it this way: you start with something and we
help you on particular questions.
But one one simply will do your homework for you...
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
