Problem with ultrasonic sensor,
Guest #5636989
• ▲ useful
▼ not useful
Hello, I am trying to make a FSM to measure distance with an Ultrasonic
sensor, but I cant seem to get rid of this latches and make my design
work, i would very much appreciate any help or comment you could give me
about how to fix it, thanks
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
use IEEE.std_logic_unsigned.all;
use IEEE.std_logic_arith.all;
entity Ultrasonic_Final is
    Port ( Clk : in  STD_LOGIC;
           Rst : in  STD_LOGIC;
           Echo : in  STD_LOGIC;
           Trig : out  STD_LOGIC;
           LEDs : out  STD_LOGIC_VECTOR (7 downto 0));
end Ultrasonic_Final;
architecture Ultrasonic_Final_Arch of Ultrasonic_Final is
  -- Any name can be used for the states
  -- The state coding given below is binary, which is the default
  -- Other state codings could have been used.
  type state_values is (st_wait,st_trigger,st_hold,st_echo);
  signal next_state, present_state : state_values;
  -- Signals used by the Frequency divider
  constant Fosc      : integer := 100_000_000;      -- Oscillator Frequency for Nexys3 board
  constant Fdiv      : integer := 1_000_000;              -- Desired Timebase Frequency
  constant CtaMax    : integer := Fosc / Fdiv;    -- Maximum count to obtain desired outputfreq
  signal   Cont      : integer range 0 to CtaMax; -- Define the counter
  signal   Timebase  : std_logic;             -- Flag used to indicate that timebase has ellapsed
  -- Cosants and signals for Ultrasonic sensor
30
  constant twait    : integer                    := 500_000;
31
  constant ttrig    : integer                    := 3;
32
  signal   tcount   : integer range 0 to 18_500  := 0;
33
  signal   tstate   : integer range 0 to 1000000 := 0;
34
  signal   duracion : integer                    := 0;
35
  signal   tiempo   : integer range 0 to 18_500  := 0;
36
  signal   centim   : STD_LOGIC_VECTOR(7 downto 0);
37
  signal   seg      : integer;
38
39
begin
40
  -- Frequency divider process to obtain a Timebase signal used by the FSM
41
  FreqDiv: process(Rst,Clk)
42
  begin
43
    if Rst = '1' then
44
     Cont <= 0;
45
   elsif (rising_edge(Clk)) then
46
     if Cont = CtaMax-1 then
47
        Cont     <= 0;
48
        Timebase <= '1';
49
      else
50
       Cont     <= Cont + 1;
51
       Timebase <= '0';
52
     end if;
53
   end if;
54
  end process FreqDiv;
55
56
  -- State Register Process
57
  -- Holds the current state of the FSM
58
  statereg: process (Clk,Rst)
59
  begin
60
    -- Asynchronous Reset
61
    if Rst = '1' then
62
     present_state <= st_wait;
63
   elsif rising_edge(Clk) then
64
     if Timebase = '1' then
65
        if duracion = tstate then
66
         present_state <= next_state;
67
        duracion      <= 0;
68
       else
69
         duracion <= duracion + 1;
70
       end if;
71
    end if;
72
   end if;
73
  end process statereg;
74
75
  -- Define the Next-State Logic Process
76
  -- Will obtain the next state based on the inputs and current state
77
  fsm: process (present_state, Echo, tcount)
78
  begin
79
    case present_state is
80
      when st_wait    =>
81
      if (Echo = '0') then
82
        next_state <= st_trigger;
83
        tstate     <= ttrig;
84
      else
85
        next_state <= st_echo;
86
        tstate     <= 1;
87
      end if;
88
      when st_trigger =>
89
90
        next_state <= st_hold;
91
        tstate     <= 1;
92
      else
93
94
        tstate     <= 1;
95
      end if;
96
      when st_hold    =>
97
98
99
        tstate     <= 1;
100
      elsif (Echo = '1') then
101
102
        tstate     <= 1;
103
      end if;
104
      when st_echo    =>
105
106
        next_state <= st_wait;
107
        tstate     <= twait;
108
        tcount     <= 0;
109
110
111
        tstate     <= 1;
112
        tcount     <= tcount + 1;
113
      end if;
114
      when others =>
115
116
        tstate     <= twait;
117
        tcount     <= 0;
118
   end case;
119
  end process fsm;
120
121
  tiempo <= tcount;
122
  seg    <= (tiempo/(1*10**6));
123
  centim <= CONV_STD_LOGIC_VECTOR((34320*seg), 8);
124
125
  -- If implementing a Moore Machine use the following process
126
  -- The output of a Moore Machine is determined by the present_state only
127
  output: process (present_state, centim)
128
  begin
129
130
     when st_wait    =>
131
      Trig <= '0';
132
      LEDs <= centim;
133
     when st_trigger =>
134
      Trig <= '1';
135
      LEDs <= centim;
136
     when st_hold    =>
137
      Trig <= '0';
138
      LEDs <= centim;
139
     when st_echo    =>
140
      Trig <= '0';
141
      LEDs <= centim;
142
      when others  =>
143
      Trig <= '0';
144
      LEDs <= "11111111";
145
     end case;
146
  end process output;
147
148
end Ultrasonic_Final_Arch;
   --WARNINGS--
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<14>>. Latches may
be generated from incomplete case or if statements. We do not recommend
the use of latches in FPGA/CPLD designs, as they may lead to timing
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<13>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<12>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<11>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<10>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<9>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<8>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<7>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<6>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<5>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<4>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<3>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<2>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<1>>. Latches may
problems.
WARNING:Xst:737 - Found 1-bit latch for signal <tcount<0>>. Latches may
problems.
WARNING:Xst:2677 - Node <tcount_12> of sequential type is unconnected in
block <Ultrasonic_Final>.
WARNING:Xst:2677 - Node <tcount_13> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_9> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_11> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_10> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_8> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_7> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_4> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_6> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_5> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_3> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_2> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_1> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_0> of sequential type is unconnected in
WARNING:Xst:2677 - Node <tcount_14> of sequential type is unconnected in
Moderator (Company: Titel) #5637046
• ▲ useful
▼ not useful
This is the problem:
That is a combinatorial loop, its a counter without registers. Thats the
most common problem when using the two-process style. You must change it
somehow like this:
  begin
   if Rst = '1' then
     tcount <= tcount_next;
   end if;
        tcount_next  <= tcount + 1;
A hint:
Never ever use both of those math packages together. You will get
strange error messages and curious behaviour now and then due to
multiple type definitions. The numeric_std has all you will need.
BTW: pls use the [ vhdl ] tags to wrap your code (as described above
each edit box)
    [vhdl]VHDL code[/vhdl]
  • [vhdl]VHDL-Code[/vhdl]
