UART RECEIVER
OP (Company: Mindteck) #5635732
• ▲ useful
▼ not useful
Hi i have written code for uart reception. I am using docklight for
transmitting data. When i transmit data at very first time, i am able to
receive correct data, but if i transmit the same data again the data is
not correct.
please find the attached code
Library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all;
entity uart_rx is
  generic (
         baudrate_clk_count : integer:=5029
  port (
       i_inclk        : in std_logic;
       i_serial_bit    : in std_logic;
       i_rx_data_bits  : out std_logic_vector(0 to 7):=(others=>'0');
       i_rx_done      : out std_logic;
       test_bench_test  : out std_logic;
       test_led      : out std_logic:='0';
       test_gpio      : out std_logic;
       o_rx_line_busy  : out std_logic
end uart_rx;
architecture behav of uart_rx is
  type rx_main_states is(rx_idle,rx_start,rx_data,rx_stop);
  signal rx_state: rx_main_states:= rx_idle;
30
  signal baud_rate_tic     : std_logic:='0';
31
32
  signal i_rx_data_byte    : std_logic_vector(0 to 7):=(others=>'0');
33
34
  signal baud_rate_counter : integer range 0 to baudrate_clk_count-1:=0;
35
  signal rx_data_r        : std_logic:='0';
36
  signal r_RX_Data_R     : std_logic:='0';
37
  signal index_reg       : integer range 0 to 7:=0;
38
39
40
41
  signal baud_rate_clock   : std_logic:='0';
42
43
  signal delay_counter     : integer:=0;
44
45
46
begin
47
48
--Baud rate clock process
49
  process(i_inclk)
50
  begin
51
    if(rising_edge(i_inclk))then
52
      if(baud_rate_counter<baudrate_clk_count)then
53
        baud_rate_counter <= baud_rate_counter+1;
54
        baud_rate_tic <= '0';
55
      else
56
        baud_rate_counter <= 0;
57
        baud_rate_clock <= not(baud_rate_clock);
58
        baud_rate_tic <= '1';
59
      end if;
60
    end if;
61
  end process;
62
63
  test_bench_test <= baud_rate_clock;
64
65
66
--Recieving the UART data frame
67
  process(i_inclk)
68
  begin
69
70
      if(baud_rate_tic='1')then
71
        r_RX_Data_R <= i_serial_bit;
72
        rx_data_r   <= r_RX_Data_R;
73
      end if;
74
    end if;
75
  end process;
76
77
--UART receiption process
78
  process(i_inclk)
79
  begin
80
81
82
83
        case rx_state is
84
85
          when rx_idle =>
86
87
            index_reg <= 0;
88
            o_rx_line_busy <= '0';
89
            i_rx_done <= '0';
90
            rx_state <= rx_start;
91
92
          when rx_start =>
93
94
            if(rx_data_r = '0')then
95
              o_rx_line_busy <= '1';
96
              rx_state <= rx_data;
97
            else
98
99
            end if;
100
101
          when rx_data =>
102
            i_rx_data_byte(index_reg) <= rx_data_r;
103
104
105
            if(index_reg<7)then
106
              index_reg <= index_reg+1;
107
108
            else
109
              index_reg<= 0;
110
              rx_state <= rx_stop;
111
            end if;
112
113
          when rx_stop =>
114
115
            if(rx_data_r = '1')then
116
117
              i_rx_done <= '1';
118
              test_led  <= '1';
119
              rx_state <= rx_idle;
120
            else
121
122
            end if;
123
124
          when others =>
125
126
127
        end case;
128
      end if;
129
    end if;
130
  end process;
131
132
  i_rx_data_bits <= i_rx_data_byte;
133
  test_gpio <= i_serial_bit;
134
135
end behav;
Moderator (Company: Titel) #5635815
• ▲ useful
▼ not useful
Hareesh M. wrote:
> but if i transmit the same data again the data is not correct.
Thats a very detailed description of your problem. Therefore its kind of
easy to find out whats going wrong...
Do you have a screenshot of your simulation? What does the testbench
look like?
What data do you send? And what do you receive?
Never ever use both of those math packages together. You will get
strange error messages and strange behaviour now and then due to
multiple type definitions. The numeric_std has all you will ever need.
  process(i_inclk)
  begin
      end if;
    end if;
  end process;
Why do you invoke the baud_rate_tic here when synching in the rx line?
Thats one of the problems here: your detection of the start bit is wrong
to to nearly "undersampling" the input signal.
The other is, that your whole receiver does not synchronize to the
edges of the start bit. Instead you simply assume that the timing is
somehow like you painted it on a sheet of paper...
In a working RS232 receiver you detect the falling edge of the startbit.
Then you wait for 1.5 bit durations. Then you sample the data bits after
each 1.0 bit durations in the mid of each bits.
In a very good RS232 receiver you detect the falling edge of the start
bit, then you wait for 0.4 bit times, then you sample the start bit
value 3 times with 0.1 bit times between the samples and check those
three samples to be all '0'. If there is one or two '1' in it, the you
set a error flag. Then you wait for 0.8 bit times and sample first data
bit 3 times with a delay of 0.1 bit times in between. When one of those
3 samples is different, then you set an error flag and take the major
value out of those 3 samples as th data bit. The same happens in the mid
time of the following data bits. And then you check the stop bit to be a
'1' in the same manner by sampling it 3 times.
OP (Company: Mindteck) #5635856
• ▲ useful
▼ not useful
> look like?
Moderator (Company: Titel) #5635897
• ▲ useful
▼ not useful
You see, thats no testbench for a VHDL design...
I urge you to set up a real VHDL testbench. Its fairly easy to generate
a simple RS232 signal and send different characters to the "unit under
test". See this for a testbench sample:
http://www.lothar-miller.de/s9y/uploads/tb_RS232IO.vhd
Then you can dig in deep and look whats going on, where are the sampling
points, hows the timing and so forth.
What FPGA clock do you have to need such an odd prescaling value?
OP (Company: Mindteck) #5636090
• ▲ useful
▼ not useful
yes, i will write test bench. Thanks for your response
i_inclk is 50mhz.
Moderator (Company: Titel) #5636132
• ▲ useful
▼ not useful
> i_inclk is 50mhz.
Fifty millihertz? Really?
If its the usual 50MHz (fifty Megahertz) then your expected baudrate is
somewhat like 50000000/5930 = 9940 bits per sec?
Looks weird to me....
Thats good.
You will get an out of range errror in this line:
Because baudrate_clk_count is 5029 and the highest adissible value for
baud_rate_counter is 5028. Therfore when baudrate_clk_count is 5028 it
is less than 5029 and finally it will become incremented. This leads to
a value higher than the allowed 5028 --> overflow error!
OP (Company: Mindteck) #5636464
• ▲ useful
▼ not useful
Lothar M. wrote:
>> i_inclk is 50mhz.
sorry!, actually the value is 5208 not 5029.
> Thats good.
yes i am getting this error.
OP (Company: Mindteck) #5636513
• ▲ useful
▼ not useful
Hareesh M. wrote:
> Lothar M. wrote:
>>> i_inclk is 50mhz.
>> Thats good.
i have solved this issue by putting
signal baud_rate_counter: integer range 0 to 5028:=0;
  • [vhdl]VHDL-Code[/vhdl]
