UART transmitter
OP (Company: Mindteck) #5629289
• ▲ useful
▼ not useful
Hi all,
I have written code for UART transmitter with 9600 baud rate. The thing
is when i simulate the code using modelsim the UART signals are find but
when i try to use terminal for transmission there is no output.
Library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity uart_tx is
  generic (
          baud_rate_divisor : integer:=520
  port (
        i_inclk         : in std_logic; --Clock input 50Mhz
        i_reset          : in std_logic; --Reset for UART transmission
        i_tx_data_bits    : in std_logic_vector(0 to 7); --8 bits of data to be send
        i_tx_start      : in std_logic; --
        o_tx_done      : out std_logic; --Bit to indicate transmission done
        o_tx_line_busy    : out std_logic; --Bit to indicate busy
        led_testing      : out std_logic;
        test_led        : out std_logic;
        o_serial_data    : out std_logic --Data to be send serially
end uart_tx;
architecture behav of uart_tx is
  type transmitter_state is(tx_idle,tx_start,tx_data,tx_stop);
  signal tx_state:transmitter_state:=tx_idle;
30
31
  signal baud_rate_clk    : std_logic:='0';
32
  signal clk_divider     : integer range 0 to 530:= 0;
33
  signal tx_data_byte    : std_logic_vector(0 to 7);
34
  signal tx_done_bit    : std_logic;
35
  signal out_clk         : std_logic:='0';
36
  signal index_counter    : integer range 0 to 7;
37
38
39
40
41
begin
42
  process(i_reset,i_inclk)
43
  begin
44
    if(i_reset='0')then
45
      clk_divider<=0;
46
    elsif(rising_edge(i_inclk))then
47
      if(clk_divider<baud_rate_divisor)then
48
        clk_divider <= clk_divider+1;
49
      else
50
        clk_divider <= 0;
51
        baud_rate_clk <= not(baud_rate_clk);
52
      end if;
53
    end if;
54
  end process;
55
56
  led_testing <= baud_rate_clk;
57
58
  process(baud_rate_clk)
59
  begin
60
    if(rising_edge(baud_rate_clk))then
61
62
      case tx_state is
63
        when tx_idle =>
64
          o_tx_done      <= '0';
65
          o_tx_line_busy <= '0';
66
          index_counter  <=  0;
67
68
          if(i_tx_start='0')then
69
            tx_data_byte <= i_tx_data_bits;
70
            tx_state <= tx_start;
71
          else
72
            tx_state <= tx_idle;
73
          end if;
74
75
        when tx_start =>
76
          o_tx_line_busy <= '1';
77
          o_serial_data <= '0';
78
          tx_state <= tx_data;
79
80
        when tx_data =>
81
          o_serial_data <= tx_data_byte(index_counter);
82
83
          if(index_counter<7)then
84
            index_counter <= index_counter+1;
85
86
          else
87
            tx_state <= tx_stop;
88
          end if;
89
90
        when tx_stop =>
91
          o_serial_data <= '1';
92
          o_tx_done <= '1';
93
94
95
        when others =>
96
97
      end case;
98
    end if;
99
  end process;
100
101
  test_led <= i_tx_start;
102
103
end behav;
and the test bench for above code is give
LIBRARY ieee  ;
LIBRARY std  ;
USE ieee.NUMERIC_STD.all  ;
USE ieee.std_logic_1164.all  ;
USE ieee.std_logic_textio.all  ;
USE ieee.std_logic_unsigned.all  ;
USE std.textio.all  ;
ENTITY tx_test_bench  IS
  GENERIC (
    baud_rate_divisor  : INTEGER   := 520 );
END ;
ARCHITECTURE tx_test_bench_arch OF tx_test_bench IS
  SIGNAL i_inclk   :  STD_LOGIC  ;
  SIGNAL led_testing : STD_LOGIC;
  SIGNAL i_tx_start   :  STD_LOGIC  ;
  SIGNAL o_tx_line_busy   :  STD_LOGIC  ;
  SIGNAL i_tx_data_bits   :  STD_LOGIC_VECTOR (0 to 7)  ;
  SIGNAL o_serial_data   :  STD_LOGIC  ;
  SIGNAL o_tx_done   :  STD_LOGIC  ;
  SIGNAL i_reset   :  STD_LOGIC  ;
  COMPONENT uart_tx
    GENERIC (
      baud_rate_divisor  : INTEGER  );
    PORT (
      i_inclk  : in STD_LOGIC ;
    led_testing : out STD_LOGIC;
      i_tx_start  : in STD_LOGIC ;
30
      o_tx_line_busy  : out STD_LOGIC ;
31
      i_tx_data_bits  : in STD_LOGIC_VECTOR (0 to 7);
32
      o_serial_data  : out STD_LOGIC ;
33
      o_tx_done  : out STD_LOGIC ;
34
      i_reset  : in STD_LOGIC );
35
  END COMPONENT ;
36
BEGIN
37
  DUT  : uart_tx
38
    GENERIC MAP (
39
      baud_rate_divisor  => baud_rate_divisor   )
40
    PORT MAP (
41
      i_tx_start   => i_tx_start  ,
42
      i_inclk   => i_inclk  ,
43
      i_tx_data_bits   => i_tx_data_bits  ,
44
      o_serial_data   => o_serial_data  ,
45
      o_tx_line_busy   => o_tx_line_busy  ,
46
      o_tx_done   => o_tx_done  ,
47
    led_testing => led_testing,
48
      i_reset   => i_reset   ) ;
49
50
51
52
-- "Clock Pattern" : dutyCycle = 50
53
-- Start Time = 0 ps, End Time = 100 ms, Period = 20 ns
54
  Process
55
  Begin
56
   i_inclk  <= '0'  ;
57
  wait for 10 ns ;
58
   i_inclk  <= '1'  ;
59
  wait for 10 ns ;
60
-- dumped values till 100 ps
61
62
 End Process;
63
64
65
-- "Constant Pattern"
66
-- Start Time = 0 ps, End Time = 10 ps, Period = 0 ps
67
  Process
68
  Begin
69
  wait until rising_edge(led_testing);
70
  i_tx_start  <= '1'  ;
71
  i_tx_data_bits  <= "10101010"  ;
72
73
  i_tx_start <= '0';
74
  wait until o_tx_done<='1';
75
---- dumped values till 10 ps
76
  wait;
77
 End Process;
78
79
end;
iam also attaching the simulated output
Moderator (Company: Titel) #5629315
• ▲ useful
▼ not useful
Drive i_reset with a defined value.
What terminal? Do you mean when you implement that design on real
hardware? What does a scope or a logic analyzer show?
This is bad design practice:
Don't use divided locally distributed clocks in a FPGA. Instead use
clock enables and only one clock overall the FPGA!
OP (Company: Mindteck) #5629376
• ▲ useful
▼ not useful
Ok i will do it. Thanks for the comment
I have connected the
o_serial_data
 to a gpio in fpga dev board and used a rs232 to usb cable to see the
output in pc
Thanks for your comment, but if i use a enable signal will i get a clock
as output. Does 9600bps baud rate generation is fine?
Moderator (Company: Titel) #5629388
• ▲ useful
▼ not useful
Hareesh M. wrote:
> I have connected the o_serial_data to a gpio in fpga dev board and used
> a rs232 to usb cable to see the output in pc
What cable?
You know, that RS232 has very different signal levels than your FPGA
output pin?
Not the way you do it.
> but if i use a enable signal will i get a clock as output.
You got lost somewhere. A clock enable is simply implemented in your
code:
  signal baud_tic   : std_logic:='0'; -- the clock enable signal
  begin
    if(i_reset='0')then
      clk_divider<=0;
    elsif(rising_edge(i_inclk))then   -- ONLY ONE AND THE SAME CLOCK in the whole design!
      if(clk_divider<1234)then        -- adapt this value
        baud_tic <= '0';
      else
        clk_divider <= 0;
        baud_tic <= '1';              -- clock enable active for one clock cycle
      end if;
    end if;
  end process;
  process(i_inclk)
  begin
    if baud_tic='1' then              -- this is the clock enable
      case tx_state is
        when tx_idle =>
          o_tx_done      <= '0';
          index_counter  <=  0;
30
31
OP (Company: Mindteck) #5629400
• ▲ useful
▼ not useful
> What cable?
> output pin?
The gpio which i have connected in fpga dev board is of 3.3V and the
rs232 voltage level range between  +3 to +15 volts or the range −3 to
−15
Moderator (Company: Titel) #5629410
• ▲ useful
▼ not useful
> rs232 voltage level range between  +3 to +15 volts or the range −3 to −15
And does this fit togeher? And does the polarity of a '1' and a '0' fit
together?
A hint: look for a levelshifter like MAX3232
Or better: look for a "ttl 3V RS232-USB adapter"
https://www.google.com/search?q=ttl+3V+RS232-USB+adapter
OP (Company: Mindteck) #5629423
• ▲ useful
▼ not useful
> together?
I have attached the cable picture.And i tried to probe the signal in CRO
also, but nothing is coming.
Moderator (Company: Titel) #5629694
• ▲ useful
▼ not useful
Hareesh M. wrote:
> i have connected the signal i_tx_start to a push button.
Just a simple button? Without a additional pullup or a pulldown? And
what signal level do you measure at that input?
What happens when you change your code in a way that the transmission
always starts on its own in an endless loop? For debugging I would add
thre additional LED and set one of them in each state of that FSM to
see, where the thing stucks.
OP (Company: Mindteck) #5629720
• ▲ useful
▼ not useful
A button with a pull down.
Actually i have tried this, and the led is set when code go into each
state.
OP (Company: Mindteck) #5629734
• ▲ useful
▼ not useful
> What cable?
> output pin?
Could you please suggest the changes??
Moderator (Company: Titel) #5629784
• ▲ useful
▼ not useful
I did. With the "clock enable" the design is whats called "synchonous".
> state.
So you see on the LED your design stepping throughout the 4 states? But
you don't see any changes on o_serial_data although its set in
tx_stop and it reset in tx_start?
Guest #5629906
• ▲ useful
▼ not useful
>> state.
Hi  Lothar ,
The signals are coming in o_serial_data. the issue was with the i_reset
signal.
Thanks for your valuable comments. Now i need to use a usb to serial
cable to see the signals in pc.
  • [vhdl]VHDL-Code[/vhdl]
