Forum: FPGA, VHDL & Verilog Scrolling a text on a 7-seg display
von Giorgia (Guest)
Hi to everyone! I write because I need help: I have to write a code to
scroll a text (such as "dE1") on a 7-seg display using four 7-bit
registers connected in a queue-like fashion, such that the outputs of
the
first register feed the inputs of the second, the second feeds the
third, and so on (pipeline). Each register’s outputs should directly
drive the seven segments of one display. A finite state machine controls
the pipeline in this way:
1. the FSM inserts the correct characters (d, E or 1) into the first of
the 7-bit registers in the pipeline.
2. After step 1 is complete, the FSM configures the pipeline into a loop
that connects the last register back to the first one, so that the
letters continue to scroll indefinitely.
My code is:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Scroll is
    Port ( clk : in STD_LOGIC;
           rst : in STD_LOGIC;
           z1 : inout STD_LOGIC_VECTOR (6 downto 0);
           z2 : inout STD_LOGIC_VECTOR (6 downto 0);
           z3 : inout STD_LOGIC_VECTOR (6 downto 0);
           z4 : inout STD_LOGIC_VECTOR (6 downto 0));
end Scroll;
architecture Behavioral of Scroll is
signal o1: std_logic_vector(6 downto 0) :="0000000";
signal o2: std_logic_vector(6 downto 0) :="0000000";
signal o3: std_logic_vector(6 downto 0) :="0000000";
type state_type is (A,B,C,D);
signal y: state_type:=A;
begin
z1<="111101" when y=B else
"1001111" when y=C else
"0110000" when y=D else
"0000000" when y=A else
"XXXXXXX";
30
process(rst,clk)
31
    begin
32
    if rst='0' then
33
        y<=A;
34
    elsif(clk'event and clk='1') then
35
36
    case y is
37
        when A =>
38
            y<=B;
39
40
41
        when B =>
42
            y<=C;
43
44
         when C =>
45
                y<=D;
46
47
         when D =>
48
            y<=B;
49
50
        end case;
51
52
        end if;
53
54
end process;
55
56
57
pipeline: process(clk,rst)
58
begin
59
   if rst='0' then
60
61
   o1<="0000000";
62
   o2<="0000000";
63
   o3<="0000000";
64
65
  for i in 6 downto 0 loop
66
  z2(i)<=o1(i);
67
  z3(i)<=o2(i);
68
  z4(i)<=o3(i);
69
  end loop;
70
71
72
 --effettuo lo shift
73
for k in 6 downto 0 loop
74
   o1(k)<=z1(k);
75
   o2(k)<=o1(k);
76
   o3(k)<=o2(k);
77
 end loop;
78
 --aggiornamento dei segnali in uscita
79
80
  for j in 6 downto 0 loop
81
  z2(j)<=o1(j);
82
  z3(j)<=o2(j);
83
  z4(j)<=o3(j);
84
  end loop;
85
  end if;
86
  end process;
87
88
end Behavioral;
This code doesn't work because the second, the third and the fourth
display are late compared to the first one of one clock cycle. Could you
help me please? Thank you very much.
> help me please?
Congratulations, you found what's called "latency". The most easy
solution for that "problem" is, to supply them one clock cycle earlier.
But in the real world with a 50MHz clock its not problem to have one
clock cycle latency here, because then the display is delayed by 20ns.
Your eye will not recognize that...
A few hints beyond that:
Are those really inout ports? If not: why do you declare it that way?
Just for laziness? That's no good idea, believe me.
   o1(k)<=z1(k);
   o2(k)<=o1(k);
   o3(k)<=o2(k);
 end loop;
You can skip the loop and cut this down to
   o1 <= z1;
   o2 <= o1;
   o3 <= o2;
Giorgia wrote:
> I have to write a code to scroll a text (such as "dE1") on a 7-seg
> display using four 7-bit registers connected in a queue-like fashion
Why do you do that so complicated with additional FSM and so on?
Why not the easy way?
library IEEE;
entity Scroll is
           rst : in STD_LOGIC;
           z1 : out STD_LOGIC_VECTOR (6 downto 0);
           z2 : out STD_LOGIC_VECTOR (6 downto 0);
           z3 : out STD_LOGIC_VECTOR (6 downto 0);
           z4 : out STD_LOGIC_VECTOR (6 downto 0));
end Scroll;
  signal o1: std_logic_vector(6 downto 0) :="0111101"; -- d
  signal o2: std_logic_vector(6 downto 0) :="1001111"; -- E
  signal o3: std_logic_vector(6 downto 0) :="0110000"; -- 1
  signal o4: std_logic_vector(6 downto 0) :="0000000"; -- blank
begin
  begin
    if rst='0' then
      o1<="0111101";
      o2<="1001111";
      o3<="0110000";
      o4<="0000000";
30
      o1 <= o2; -- scroll the text (fairly fast at some MHz clock...)
31
      o2 <= o3;
32
      o3 <= o4;
33
      o4 <= o1;
34
    end if;
35
  end process;
36
37
  z1 <= o1;
38
  z2 <= o2;
39
  z3 <= o3;
40
  z4 <= o4;
41
42
end Behavioral;
BTW: pls wrap your VHDL code with the [vhdl] tokens as described a few
lines over each edit-box.
BTW2: with proper indention your code gets more readable.
von Giorgia (Guest)
Now it's working! Thank you very much!
I added a FSM because the exercise requires it. Do you think it's too
complicated?
Each simple counter is a FSM.
> Do you think it's too complicated?
No, it's a nice exercise.
