Package for parametric design
Guest #5614379
• ▲ useful
▼ not useful
I need to design & verify parametric design, such that my design & verif
env will be instantiated twice, each time with different parameters.
I usually work with packages for my design, so all of parameters,
structs etc are defined there.
My questions:
Is there a  way to write such package so same package will hold same
parameter  with two different values? (different value for each
instance)
Thanks!
Moderator (Company: Titel) #5614452
• ▲ useful
▼ not useful
Ido wrote:
> I need to design
In what language?
> parameter  with two different values? (different value for each instance)
In VHDL there are "generics": one "universal" (=generic) description and
two (or more) instances with different (but static) parameters.
Guest #5614456
• ▲ useful
▼ not useful
Lothar M. wrote:
> Ido wrote:
>> I need to design
> In what language?
> Verilog/system verilog
Is there similiar solution in verilog/system verilog?
Thanks
  • [vhdl]VHDL-Code[/vhdl]
