Procedure in VHDL testbench
Guest #5610574
Hello there,
I am trying to implement a procedure in my testbench to shorten the
lenght.
entity tb is
end entity;
architecture sim of tb is
  procedure P_DATA(
      constant ctrl  : in std_logic_vector (8 downto 0);
      constant ht    : in std_logic_vector (16 downto 0);
      constant prd   : in std_logic_vector (16 downto 0))
      is
      variable i_sctrl  :  std_logic_vector (8 downto 0);
      variable i_sprd    :  std_logic_vector (16 downto 0);
      variable i_sht     :  std_logic_vector (16 downto 0);
 begin
     i_sctrl  := ctrl;
     i_sprd   := prd;
     i_sht    := ht;
 end procedure;
  signal i_clk   : std_logic;
  signal i_rst   : std_logic;
  signal i_sctrl : std_logic_vector (8 downto 0);
  signal i_sprd  : std_logic_vector (16 downto 0;
  Signal i_sht   : std_logic_vector (16 downto 0;
begin
  -- Data generation
30
  pr_int : process
31
  begin
32
33
      i_rst <= '1';
34
      i_sctrl <= (others => '0');
35
      i_sprd  <= (others => '0');
36
      i_sht   <= (others => '0');
37
      wait for 5 ns;
38
      i_rst <= '0';
39
      wait for 2 ns;
40
      wait for rising_edge(i_clk);
41
      P_DATA(X"04", X"0009",X"000A");
42
      wait for 1 ns;
43
      wait;
44
45
     end process;
46
47
end architecture;
When I simulate to above Code my inputs data are all "zero" all the
time. How can I modify the procedure to get the set values in the
simulation waveform
Many thanks
Guest #5611686
The signals i_sctrl, i_sprd and i_sht are in a diffrent scope, than the
variables with the same name inside the procedure.
If you want zu use them, you have to add them to the parameter list:
  procedure P_DATA(
      constant prd   : in std_logic_vector (16 downto 0);
      signal x_sctrl : out std_logic_vector (8 downto 0);
      signal x_sprd  : out std_logic_vector (16 downto 0);
      signal x_sht   : out std_logic_vector (16 downto 0);
      is
 begin
     x_sctrl  <= ctrl;
     x_sprd   <= prd;
     x_sht    <= ht;
 end procedure;
P_DATA(X"04", X"0009",X"000A",i_sctrl,i_sprd,i_sht);
Duke
Guest #5612045
> than the
> procedure P_DATA(
>       is
>  begin
>      x_sctrl  <= ctrl;
>      x_sprd   <= prd;
>      x_sht    <= ht;
>  end procedure;
> Duke
Hi Duke,
Thanks a lot. It's a exactly what I wanted to do. It works like a charm
Many Thanks
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
