APA107 white digital led strip, can replace dotstar apa102?
Guest #5610319
APA107 has 4 pins, APA102 has 6.
APA107 only has a data-pin, APA102 has pins for data and clock.
Its not a drop-in replacement.
Guest #5614537
Jessy J. wrote:
> Why did you make that datasheet???? I am very curious.
> This is the real datasheet...
No. This is a jpeg image - not a datasheet.
And no. Yesitsme did not made the datasheet. Like you he randomly
selected a document from the internet. Actually the vendor wrote two
datasheet documents with the same name "SPC/APA107".
 1) https://datasheetspdf.com/pdf-file/1273359/NEWSTAR/APA107/1
 2) https://cdn.hackaday.io/files/21293910999712/APA107%20RGB.pdf
The later one with revision number 01 seems to be the current valid one,
as it is the version available on the homepage of newstar.
  http://www.newstar-ledstrip.com/productshow817.html
  -> http://www.newstar-ledstrip.com/product/20180820112602493.pdf
Miguel T. wrote:
> can I use it to replace dotstar apa102 white?
It seems to be what newstar has in mind when writing:
"APA107 will be upgraded again, the PWM can be 26-28kHz, faster and
cheaper than APA102."
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
