Word Processing using verilog
Guest #5590861
• ▲ useful
▼ not useful
Hi all.
Ive a stream of DNA sequence.
A G T G C T T G
and I want a output of
input   A G T G C T T C
outputs A G
        A G T
          G T G
            T G C
              G C T
                C T T
                  T T C
                    T C
For now what I think is to used Shift Register (Serial In Serial
Out(SISO)). Below the the SISO and its testbench verilog code.
module SISO (Clk, Load, SIn, SOut);
  parameter PE = 3;
  parameter QCbit = 3;
   input  Clk, Load;
  input  [QCbit-1:0] SIn;
   output [QCbit-1:0] SOut;
   reg [(QCbit*PE)-1:0] sr ;            //3 x 3QC  = 24 bits
  always@(posedge Clk)
    begin
      if (Load)
        begin
          sr <= {sr[2:0], SIn};  //shift by 2 and concatenate Input
        end
      else
         begin
          sr <= 1'd0;
         end
    end
assign SOut = sr[5:3];            // complete shiftreg is serially output
endmodule
module SISO_tb();
  /*parameter InWidth = 3;*/
  localparam
    N_A         = 3'b000,        //nucleotide "A"
    N_C         = 3'b001,        //nucleotide "C"
    N_G         = 3'b010,        //nucleotide "G"
    N_T         = 3'b011;        //nucleotide "T"
  reg            Clk,Load;
  reg     [2:0]  SIn;
  wire    [2:0]  SOut;
initial
  begin
    Clk = 0;
    forever
      begin
        Clk = 0; #20;
        Clk = 1; #20;
      end
  end
initial
  begin
    Load = 0; #10;
    Load = 1; #600; // 2*length of SISO
    Load = 0; #10;
30
  end
31
32
initial
33
  begin
34
    SIn = N_A; #30;
35
    SIn = N_G; #40;
36
    SIn = N_T; #40;
37
    SIn = N_G; #40;
38
    SIn = N_C; #40;
39
    SIn = N_T; #40;
40
    SIn = N_T; #40;
41
    SIn = N_C; #40;
42
  end
43
44
initial
45
  begin
46
    #700$finish;
47
  end
48
49
SISO SISO_inst(
50
                .Clk      (Clk),
51
    .Load     (Load),
52
    .SIn      (SIn),
53
    .SOut     (SOut)
54
55
56
endmodule
Is it possible to produce that kind of word output using SISO?
Do you guys have idea?
Moderator (Company: Titel) #5591030
• ▲ useful
▼ not useful
dayana42200 wrote:
> I want a output of
There is no clock or timing information in that picture. I don't get the
trick. So some question remain:
> outputs A G
>         A G T
The output length is variable?
> A G T G C T T G
You get one "character" with each clock?
Whats happening with thoe two in the simulator?
And whats wrong with that whats happening?
What do you expect and what do you get instead?
Guest #5592051
• ▲ useful
▼ not useful
  I want the output in every clock cycle.
  Yes as shown in the output pattern.
  Yes as shown in the attached waveform.
As you can see, in the attached waveform, it is just a normal SISO that
works. I expect the output pattern that I show and I have no idea how to
process the DNA stream.
  • [vhdl]VHDL-Code[/vhdl]
