wired_and , wired_or VHDL
OP #5568726
Hi everyone!. In my project I have some moduls (each one has two outputs
called calck_out(std_logic) and z_out (std_logic_vector(16bits)).
I need to leave only 1 module, just the one that will have clack_out =
1.
I have readed abbout wired-and and wired-or but i don't understand that!
:C
I should to use bus instead of signals?. hoy i can make it?
Please help me. if Somebody can explain me: wired-and and wired_or
related wit my project at the same time, that will be very usefull.
Each one have clack_out and z_out. thanks a lot
component neurona
    Port ( x_in : in  STD_LOGIC_VECTOR (15 downto 0);
           proto_in : in  STD_LOGIC_VECTOR (1 downto 0);
           izq_in : in  STD_LOGIC;
        clack_in : in STD_LOGIC;
        clack_history_in : in STD_LOGIC;
           clk : in  STD_LOGIC;
           reset_in : in  STD_LOGIC;
           rec_out : out  STD_LOGIC;
           der_out : out  STD_LOGIC;
        clack_out : out STD_LOGIC;
        clack_history_out: out STD_LOGIC;
        proto_out: out STD_LOGIC_VECTOR(1 downto 0);
           z_out : out  STD_LOGIC_VECTOR (15 downto 0));
end component;
Moderator (Company: Titel) #5568804
Aldemaro G. wrote:
> Somebody can explain me: wired-and and wired_or related wit my project
First: forget about such a hardware specific detail like wired-and and
wired-or. Just write the function in a way it is best readable and don't
think about its implementation.
Do you want that just for simulation? Or will it go into real hardware
like a FPGA?
All in all: what is your actual problem? And why do you think the only
way to solve it are those wired-and/wired-or?
OP #5568831
> like a FPGA?
 real hardware, just a FPGA.
the problem is:
I have n data, but i want to leave just 1. (like a multiplexor) but
I don't have a select signal, I need to detect wich one module have
"clack" 1 and let it leave
I can create and decoder to do it. but is better to use wired-and or
wired-or? I don't know.
Guest #5568841
Its still open, for which reason you think, you must or shall use a
wired-or or a wired-and.
If the "thing" shall output:
a) a one, if any of the inputs is one
and
b) a zero, if none of the inputs is one (in other words: each and every
input is zero)
this perfectly matches the description of an OR-Gate.
So again: Why do you think, you shall use a wired-or?
Guest #5568863
THERE IS NO WIRED AND OR WIRED OR IN FPGAs
THERE ARE ONLY WEIRED ANDS AND ORS PREDEFINED BY PERSONS HAVING HAD
LEARNED VERILOG OR VHDL BY SELF STUDIES AND FACEBOOK AND HAVING REPOSTED
THEIR WEIRED UNDERSTANDING REGARDING DIGITAL ELECTRONICS IN NEWSGROUPS
TO SHOW OFF.
GO TO A UNIVERSITY AND LEARN ELECTRONICS FROM TEACHERS HAVING UNDERSTOOD
DIGITAL DESIGN AND IGNORE THE BULL ALL AROUND.
OP #5568882
thanks for this answer, I didn't know this.
ok well, Just a teacher recommended me use it, thanks for your advice.
I'm sorry if I bothered you.
Moderator (Company: Titel) #5569148
How old is he/she?
Aldemaro G. wrote:
> let get out the data when clack is 1.
What "data"?
Is "z" the "data"?
And "c" should get that "z" from where "clack" is '1'?
And it is for sure that only 1 of theose "clack" are active at the very
same time?
Then I would do it this way in VHDL:
   c <= az when aclack='1' else
        bz when bclack='1' else
        ez when eclack='1' else
        fz;
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
