Verilog : postive Edge Trigger
OP #5564068
• ▲ useful
▼ not useful
I am generating Trigger Signal and counter data in single Verilog code.
Logic (verilog): 1. Generating Trigger Signal for 500ns -Output Port
trig_out
                 2. Generating counter data (counter_result)
                 3. collecting and Storing counter data (Final_Value) at
every Positive edge of trigger signal.
detect Port- Positive Edge detector of trigger signal.
Please debug my code. Because i am unable to collect the edge value
(counter value) of Trigger signal.
module Counter_Design
#(parameter N = 25)
    input clk,
    input rst,
    input enable,
  output reg[31:0] Final_value,
    output reg trig_out
reg [31:0]counter;
reg [31:0] counter_result;
reg temp1;
wire detect;
wire temp2;
always @(posedge clk or posedge rst) begin
  if (rst) begin
    // reset
    counter <= 0;
  end
  else if (counter == N-1) begin
    counter <= 0;
  end
  else if (enable==1'b1)
  begin
    counter <= counter + 1;
  end
end
30
31
begin
32
  if (rst) begin
33
    // reset
34
    trig_out <= 0;
35
  end
36
37
    trig_out <= !trig_out;
38
  end
39
end
40
41
begin
42
  if (rst)
43
  begin
44
    // reset
45
    trig_out <= 0;
46
  end
47
    else begin
48
      temp1 <= trig_out;
49
     end
50
end
51
assign detect=trig_out & ~temp1;
52
 assign temp2=temp1&&clk;
53
54
always @(posedge temp2 or posedge rst)
55
begin
56
  if (rst)
57
  begin
58
     counter_result<=0;
59
  end
60
    else begin
61
      counter_result<=counter_result+1;
62
     end
63
end
64
always @(posedge detect or posedge rst)
65
 begin
66
    if(rst)
67
    begin
68
    Final_value<=0;
69
    end
70
71
    Final_value<=counter_result;
72
    end
73
end
74
endmodule
Guest #5566033
• ▲ useful
▼ not useful
At first: Write a testbench, so that others can reproducible your
problem:
module counter_tb;
    // testbench signals
    reg tb_clk;
    reg tb_rst;
    reg tb_enable;
    wire [31:0] tb_final_value;
    wire tb_trig_out;
    // design under test
    Counter_Design DUT (
        .clk            ( tb_clk),
        .rst            ( tb_rst),
        .enable         ( tb_enable),
        .Final_value    ( tb_final_value),
        .trig_out       ( tb_trig_out)
    // stimuli
    initial
    begin
        tb_clk = 0;
        tb_rst = 1;
        tb_enable = 0;
        # 7 tb_rst = 0;
        # 55 tb_enable = 1;
        # 99 tb_enable = 0;
        # 135 tb_enable = 1;
30
        # 1000 $finish;
31
    end
32
33
    // clock generator
34
    always
35
        #5 tb_clk = ~tb_clk;
36
37
endmodule
I attached a slightly modified version of your code, which update
Final_value when the counter is reseted. Maybe I didn't understand you
correctly with you problem.
Duke
Moderator (Company: Titel) #5566053
• ▲ useful
▼ not useful
> Because i am unable to collect the edge value (counter value) of Trigger
> signal.
You are generating that value. So it should be very easy to do any
processing there.
It is no good design practice to use gated clocks. Absolutely not! A
hint for the beginner: use only 1 clock in the whole FPGA and do all
enabling inside the clock processing, somewhat like this:
begin
  if (rst)
  begin
     counter_result<=0;
  end
    else begin
      // do the clock-enabling here
      if (clock_enable)
      end
     end
end
It is no good design practice to use any random input as a clock source.
Treat that "detect" signal as a simple input and synchronize it to the
OneAndOnly-FPGA-Clock. Then store it in two flipflops one after the
other and compare the values of those two flipflops to detect an edge of
that input signal. This is called synchronous design. And thats the only
thing that works reliably in the real world...
Whats the problem with it?
> Because i am unable to collect the edge value of Trigger signal.
How did you find that out? What do you expect of that code? And what do
you get instead?
Where in your description is a repetition of the Trigger Signal? I can't
find no one.
> 1. Generating Trigger Signal for 500ns -Output Port trig_out
So only one Trigger pulse must be generated.
From what? When should the counter stop?
> 3. collecting and Storing counter data (Final_Value) at every Positive
According to 1. there is only 1 Trigger Signal active once for 500ns.
Shoul the trigger start later on once more? After a certain time? Or a
certain event?
Can you draw a sketch of that timing of those few signals and the
desired reaction?
  • [vhdl]VHDL-Code[/vhdl]
