SWD for STM32F4VGT6
Guest #5559064
Hello,
I got a cheap barebones STM32F4VGT6 board, admittedly it was somewhat of
an impulse buy. It is made by diymore:
https://www.ebay.com/itm/STM32F407VGT6-ARM-Cortex-M4-32bit-MCU-Core-Development-Board-STM32F4Discovery-/311702413371
So far, I have used dfu-utils to burn my programs, which are generated
by STM32CubeMX. The dfu-utils method is described here:
https://github.com/dwelch67/black_pill_too
I would like to use a NUCLEO boards' SWD programmer to be able to debug
the MCU, but it does not break out the reset pin. Nonetheless, on the
back side silk screen it says:
SWD: PA13/DIO PA14/CLK
Do I have to pry the NRST line from the reset button, or can I use just
those 2 lines for SWD?
Thanks for your help.
#5559105
Those two pins are sufficient for SWD (together with a GND connection
obviously). You do not have to route the rst-Pin to your ST-Link unless
you e.g. want to do a "connect under reset" but you could also do that
manually by holding the reset button and releasing it after initiating
the debug connection.
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
