ERROR - Design is empty
Moderator (Company: Titel) #5559005
• ▲ useful
▼ not useful
When there is no reaction to the outer world (e.g. no outputs assigned)
then the synthesizer comes to the conclusion that you will never see,
whats inside the FPGA. And therefore all of the design is optimized
away.
Same with input signals: when they are not assigned to the outer world,
then the synthesizer selects the value leading to the most efficient
design. And then maybe most of the design is optimized away and/or
truncated down to a constant value.
Guest #5560083
• ▲ useful
▼ not useful
Thank you for your answers
I checked and found warnings like that :
port XXX remains unconnected for this instance.
I guess it is due to some ports that are not connected as you said.
I got rid of all warnings but I still have this one :
WARNING - C:/Users/Mesotic/Desktop/Fusion/csi2_2_csi2_ip.v(509,1-568,3)
(VERI-1927) port d1_p_i remains unconnected for this instance
d1_p_i is an inout port which is declared in DPHY_2_CMOS module.
I instantiated the DPHY_2_CMOS module in an other module which is called
csi_2_csi.
This is the instantiation and d1_p_i is connected to d1_ch1_p_i :
dphy_2_cmos_ip dphy2cmos_ch1 (
        .reset_n_i (reset_n_i),
        .reset_byte_n_i (reset_n_i),
          .reset_byte_fr_n_i (reset_byte_fr_n_i),
        .reset_lp_n_i (reset_lp_n_i),
        .clk_lp_ctrl_i (clk_lp_ctrl_i),
        .clk_pixel_i (1'b0),
        .pll_lock_i (tx_pll_lock),
        .lp_d0_tx_en_i (1'b0),
        .lp_d0_tx_n_i (1'b0),
        .lp_d0_tx_p_i (1'b0),
        .reset_pixel_n_i (1'b0),
      `ifdef RX_CLK_MODE_HS_LP
        .clk_byte_fr_i (rx_byte_clk_fr_ch1),
      `elsif RX_CLK_MODE_HS_ONLY
        .clk_byte_fr_o (rx_byte_clk_fr_ch1),
      `endif
        .clk_p_i (clk_ch1_p_i),
        .clk_n_i (clk_ch1_n_i),
      `ifdef NO_OF_LANE_1
        .d0_p_i (d0_ch1_p_i),
        .d0_n_i (d0_ch1_n_i),
        .bd_o (ch1_byte_data0),
            `elsif NO_OF_LANE_2
        .d1_p_i (d1_ch1_p_i),
        .d1_n_i (d1_ch1_n_i),
        .bd_o ({ch1_byte_data1,ch1_byte_data0}),
      `elsif NO_OF_LANE_4
        .d2_p_i (d2_ch1_p_i),
        .d2_n_i (d2_ch1_n_i),
        .d3_p_i (d3_ch1_p_i),
        .d3_n_i (d3_ch1_n_i),
        .bd_o
({ch1_byte_data3,ch1_byte_data2,ch1_byte_data1,ch1_byte_data0}),
      `endif
        .lv_o (),
        .fv_o (),
        .wc_o(wc_ch1),
      `ifdef LR
        .vc_o(vc_ch1),
      `endif
      // debug pins
        .lp_en_o (lp_en_ch1),
        .sp_en_o (sp_en_ch1),
        .dt_o (dt_ch1),
                                .payload_en_o(d2c_payload_en_ch1),
        //.hs_en_o (hs_en_ch1),
        .hs_sync_o (hs_sync_ch1),
        .lp_hs_state_d_o (lp_hs_state_ch1),
        .d0_p_io (),
        .d0_n_io ()
I don't now how to resolve it.
Thank you beforehand.
  • [vhdl]VHDL-Code[/vhdl]
