More toggles than expected.
Guest #5535185
• ▲ useful
▼ not useful
I have a process in my VHDL code that I want to advance a counter on a
rising edge if an input(GPIO_READDATA(6) an encoder output much slower
than 50 MHz. All entities are std_logic. cntr[32] and READ_DATA[7]are
vectors.
My code is as follows:
  Catch_Rising_Edge: process(CLK)
  begin
  if rising_edge(CLK) then -- 50MHz clk
    r0_input <= GPIO_READDATA(6); --reading GPIO_READDATA(6)
    r1_input <= r0_input;
    ENC(1) <= GPIO_READDATA(6); -- ENC(1) drives a single LED
    if  (r1_input <= '0') and (r0_input <= '1')then
      cntr <= cntr+ 1; -- cntr(22 downto 15) drives a string of 8 LEDs
    end if;
  end if;
  end process;
My understanding is on a rising CLK, the first 4 lines occur
simultaneously. The 5th line being a condition of the 4th also should
occur simultaneously.
On the rising edge transition of GPIO_READDATA(6), r0 goes to '1' and r1
stays at '0' because it reads r1 before r0 transitions. In the start of
the next CLK cycle, r0 = '1' and r1 = '0' so the cntr advances.
However, that is not what is happening. When ENC(1) is low, cntr(22) is
flashing at about 1 Hz making my cntr count at 50MHz. When ENC(1) is
high, cntr stops. I am trying to understand ModelSim to further solve
the issue. Please help me find the error in my code.
Thank you
Guest #5535369
• ▲ useful
▼ not useful
I just tried that and it I cannot get it to work.
Catch_Rising_Edge: process(CLK, GPIO_READDATA(6))
  begin
    if rising_edge(GPIO_READDATA(6)) then
      cntr <= cntr+ 1;
    end if;
  end if;
  end process;
I get ... can't infer register for "cntr[1]" because its behavior does
not match any supported register model
I also get 21 other similar errors.
I am a novice and was told to only implicitly trigger on a clock edge.
What am I missing?
Moderator (Company: Titel) #5536295
• ▲ useful
▼ not useful
bob wrote:
    cntr <= cntr+ 1;
  end if;
end if;
Just to clarify the issues here:
Of course this code is not synthesizeable, because
1. it requires the cntr to be built with never seen "dual clock input
flipflops" and
2. in real life there are no edges at the very same time as this code
demands...
  • [vhdl]VHDL-Code[/vhdl]
