Shift-In PCB to buy (e.g. using CD4021 or 74HC597) with Arduino Mega
OP #5524544
Hi @ll,
I got an old railroad switchbox controlboard which originally was
connected to a heap of relays. I need to revive it using todays
electronics. At the moment I favor an Arduino ATmega for control.
The switchbox control has around 100 push-buttons that I have to read
in. No more than two push-buttons should be pressed simultaneously.
Question 1 - how would you do that?
I was thinking to use two or three chains of shift registers (the 4021
or 597 mentioned in the subject). I am not so much into soldering so I'd
prefer to use some well-designed prefabricated boards for the task
(instead of learning how to design PCBs myself, which might or might not
work out in time). But my search parameters did not find me anything
useful.
Question 2 - Do you know of such a PCB? Ideally it would be supplemented
by a library to adress it easily, but that is not a must.
Thanks in advance, Walter
OP #5532064
Hi Thomas,
thank you so much for your answers! I will consider those boards that
you mentioned, the I2C looks tempting.
The only downside on those options is that they just provide 8
connections. The I2C board allows for 8 different adresses, so I would
need at least two separate buses to add up to my approximately 100 input
pins (2x8x8).
Therefore, if anyone can point me to an input board with even more pins
provided, I would be grateful!
Cheers, Walter
#5532373
Hi Walter
> connections.
Yes, this I2C boards are limited.
I've found two other boards with 16 x IO, but this is also insufficient
https://de.aliexpress.com/item/OPRN-SMART-PCF8575-IO-Expander-Module-I2C-to-16IO-I2C-to-16-bit-IO-expansion-breakout/32804822741.html
https://de.aliexpress.com/item/-/32859752451.html
So it would be the best choice this 595 board as suggested bevore:
https://de.aliexpress.com/item/74HC595-Shift-Register-Breakout-CJMCU-595-8-bit-shift-register/32807747744.html
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
