Ds18b20 Problem
OP #5504260
Hello,
I am trying to use a DS18b20 sensor with a STM32 Discovery board.
However, I did the mistake of trying to connect the sensor to the PC
using a RS232 to USB converter instead of TTL to USB. I know that the
voltage levels for the normal RS232 is way higher than the 3.3-5V range
of the sensor. I cant find any problems with the Simulink program that I
am using, but don´t seem to get any response from the sensor. I also
tried using a program from the following website:
https://www.seanet.com/~karllunt/onewire_stm32f4.html
The scratchpad shows only a sequence of "FF"s. Is it possible that the
sensor is damaged? Is there any sure way to establish that? I would
really appreciate if someone can help.
Moderator (Company: Titel) #5504280
How did you do that? The DS18B20 has no matching serial interface...
Take a scope and measure whether any kind of communication happens at
all. and post a schematic of your wiring.
OP #5504368
Hello Lothar,
Thank you for your reply. I used a STM32 board in between, but I was
trying different things, so I am not sure whether I have already exposed
the sensor to the overvoltage.
I have attached a schematic of the current wiring, along with the
simulink programs that I am using. The ´Target´ refers to the
microcontroller and the ´Host´ to my PC.
I tried with a scope to check the communication, but can´t find
indication that the communication is running.
Guest #5504537
If not shure (and not able to perform a "cross-check" with code, known
as "did work previously"): assume you did kill the sensor by
overvoltage.
->Buy a new one.
Maybe, that is a mistake and you wastes the money for one sensor. But
the effort is much less in comparision to the case you actually killed
the sensor...
Moderator (Company: Titel) #5504554
Between what? The STM32 and the DS18b20?
> but can´t find
Is the STM32 running as expected? Then at least you should see a
one-wire reset pulse on the data line..
OP #5505395
Thanks for the replies. So I tried using the scope again. I am indeed
using it in between the STM32 and DS18b20. It seems last time the time
scale was too short to see that. I can see that the STM32 is running
fine. It sends the reset pulse and it reads the sensor as well. But it
reads only "FF"s and if I convert it to temp I get a value of 32767.5
degrees. Is this an indication of some fault? Can't find anything in the
datasheet or in other forums though.
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
