31kHz PWM MOSFETs get hot but stay cold at 3.9kHz
Guest #5474670
• ▲ useful
▼ not useful
First, my project is to heat up and cool down a system with a
thermoelectric cooler (TEC). To power the TEC with a variable DC voltage
I created a H-bridge with a ring-core choke, controlled by an Arduino
Micro. My problem is, to minimize the AC voltage at the output I want to
use a higher PWM frequency. With 3.9kHz I have no thermal issues but a
highly rippled DC voltage at the output. With the next higher frequency
(8 times higher) of 31kHz I get an ok DC output but the MOSFETs on the
PWM side get hot. The DC output current in both cases is the same. With
50% duty cycle about 4A, not really significant for the MOSFETs. The
MOSFETs I use are "IRFZ44N" with the gate drivers "IR2104". One side of
the h-bridge is controlled by a PWM signal and the other side is pulled
to the ground while heating and while cooling vice versa.
My thoughts are that the gates of the MOSFETs are not charged/discharged
fast enough. The gate charge in my case is 50nC and the gate current is
limited by a 100ohm resistor down to a maximum of 120mA (driver can
handle 130mA). This should not be a problem for 31kHz, does it?
Thank you for your help.
Guest #5474687
• ▲ useful
▼ not useful
> fast enough.
That's right.
> handle 130mA).
The driver can handle 130mA DC - the pulsed current may be much
higher, and without any problem.
It does. Try gate resistors of 22 ohms or less, then it should work
right.
Guest #5474694
• ▲ useful
▼ not useful
> not charged/discharged fast enough.
Yes, I would also check that at first.
The Gate has a capacity of about 1.5nF, the Gate resistor in 100 Ohm. So
the charging time would be a somewhat more than 750ns (R*C*5).
31kHz frequency has a pulse width of 16µs.
So gate charging time should be a very small fraction of that 16µs which
is the case. Also 4A is not that much.
It seems that you have an issue with the charge pump or wrong resistors.
I assume that only the PWM side becomes hot, right?
Guest #5474699
• ▲ useful
▼ not useful
The blocking caps (C1 to C4) should be paralleled with small value low
impedance caps - maybe foil or ceramic. Most importantly the caps for
bootstrap, C1 and C3. Place some 100nF to 1µF caps beneath them.
If you don't want to use such low frequencies any more, but stay at
30kHz, then C1 and C3 can besmall value low impedance themselves - the
electrolytics with 100µF are not necessary then.
And which type of diodes (D1, D2) did you use for bootstrap? They should
be rather fast for 30kHz.
Guest #5474707
• ▲ useful
▼ not useful
When I look at example schematics in the internet I see that most of
them use 10 Ohm resistors in front of the gates.
But what's wrong with my calculation? I wrote above that the chargint
delay due to the R and Gate capacitance would be somewhat more than
750ns. Lets assume 1ms. This is a small fraction (1/16) of the pulse
width.
The maximum thermal load would occur when the transistor hals half of
the load voltage, which would be 10V at (estimated) 2A, so 20W.
20W * 1/16 = a little more than 1W. With a small heatsink, the
transistors should be able to handle that.
Or am i wrong?
Guest #5474717
• ▲ useful
▼ not useful
You should use a driver with separate inputs for low and high driver and
a controller with dead time generation for both complementary PWM
outputs, e.g. Attiny85 or Attiny861.
Then adjust the dead time to the shortest value, where without load the
lowest current was consumed.
Guest #5475509
• ▲ useful
▼ not useful
Thank you for your answers.
D1 and D2 are SB 160 Schottky diodes. I just looked for Schottky and
bought the first type which appeared.
First I will try out lower gate resistors, but there is a question. In
the datasheet of the driver is written "Output high short circuit pulsed
current: Min 130mA Typ 210mA, Test Conditions: VO=0V PW<10us". For me,
this is the maximum current, not the average current and a 22ohm gate
resistor will reach with the 12V a peak of 545mA. Average with the 50nC
and a switching frequency of 31kHz I will be a DC current of irrelevant
low 1.5mA, so not sure if they really mean DC current in the specs.
However, I already ordered new driver (IR2183) with a peak current of at
least 1.4A. Before they arrive, I will try out a lower resistance than
recommended with the old driver. If they get damaged its not a huge loss
(the circuit is connected to a current limited supply, so there should
be no damage to the expensive parts)
If a lower gate resistance is not the answer, I will add
non-electrolytic capacitors to the bootstrap. In future, I will swap
them for sure, but now I would wait for more Items needed, instead of
paying the shipping just for a couple of capacitors.
With a heatsink, I guess I can deal with the temperature, but that would
be the last option because the circuit should get as compact as
possible. The maximum output current I want to reach is about 10A and
that only for a few seconds until the TEC has created a relevant
temperature difference.
Use separate high and low inputs with an extern dead timer is not
necessary I guess, so I would prefer to use a comfortable version with
everything integrated.
Guest #5476169
• ▲ useful
▼ not useful
Also think, that the problem is a shot thru, there is a short periode,
where both FETs are "open". (Peter D.: dead time) You can try to solve
it by an "analog" way, a R-D-C-combination. Use the diode to discharge
the gate, R to charge and small C to GND to fit the time constant.
greetings
Achim
#5490711
• ▲ useful
▼ not useful
I took some time with the order and resoldering almost everything but
now with other gate drivers (IR2183 with 1.4A) and 10ohm gate resistors,
the MOSFETs get a little warm with 31kHz after a long time with 5A.
Hopefully they wont get much warmer with full power with a stronger PSU.
Sadly the new gate driver has other lead assignment so I had to resolder
almost everything.
Thanks everyone for helping me out.
