Record port map in VHDL
Guest #5466095
hello guys,
I need some help with the port map in VHDL
 I have to port map a module to the top module something like
 port map ( a => b)
 the Problem is that b has been define in a record something like:
 type x is record
 y : foo_in;
end record;
and
 type foo_in is record
     b: std_logic;
end record;
What I have done is create a Signal
 Signal t : x
port map (
  a => t.b
I don't think my port map is correct. What will be the proper way to do
it.
Many thanks
Moderator (Company: Titel) #5466129
And whats the problem with it?
What error does what compiler report to you?
And please post a code snippet thats somehow compilable and simulable.
> What will be the proper way to do it.
What type is a?
Guest #5466145
Hi Miller,
Thanks for your Reply
a and b are both std_logic type  port signal. I have a Problem with the
record in the middle.
I mean if I have to do
 port map (
   a => t.y.b;
or
 port map(
   a => t.foo_in.b;
Thanks
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
