Cpu: why only on posedge?
OP #5464506
• ▲ useful
▼ not useful
I've been training my fpga skills but I still have a question.
https://github.com/ejrh/cpu/blob/master/rtl/alu.v
This page is a cpu ALU.
I am wondering why we should wait on a posedge to restrict the execution
flow. We could have better parallelism, albeit with a supporting
compiler.
Thanks
Guest #5464515
• ▲ useful
▼ not useful
> compiler.
There are asynchrounous designs but mostly there a larger than the
synchronous ones.
http://haltenraum.com/article/asynchrone-schaltung
https://en.wikipedia.org/wiki/Asynchronous_circuit
http://www.tkt.cs.tut.fi/kurssit/3520/K13/CH_16.pdf
https://en.wikipedia.org/wiki/C-element
Moderator (Company: Titel) #5464537
• ▲ useful
▼ not useful
Mark L. wrote:
> wondering why we should wait on a posedge to restrict the execution flow.
How do you expect to get a working adresscounter without a clock? (a
hint: a "combinatorial loop" is usually not desirable in a design).
How would you read code without an consistent adresscounter?
Mark L. wrote:
> Ok, so  if I understand correctly adding negedge is a bad idea here
It virtually doubles the clock frequency in your design. Because it
leaves you only half the time to setup for the next active clock edge.
In fact due to an asymmetric clock it's a little bit more than factor 2.
Moderator (Company: Titel) #5464787
• ▲ useful
▼ not useful
Mark L. wrote:
> So with a negedge, the whole system becomes unpredictable
No, it's perfectly predictable as long as you specify the clock
correctly to the toolchain.
When having only one active clock edge (only rising or falling) and your
logic needs 10ns to get stable then you get something around 100MHz.
When using both edges as active edges and your logic needs 10ns to get
stable, then you need that time between two consecutive edges, then you
must halve your clock frequency to 50MHz.
So at the end nothing is won.
  • [vhdl]VHDL-Code[/vhdl]
