Clear_preset flip flop inputs
Guest #5454415
• ▲ useful
▼ not useful
Hi All
If I am writing a VHDL code, for a flip flop that includes clear and
reset inputs, both active when 'low', how do i make provision for this
for the case when clear = 0 and preset=0, that is the case that produces
invalid output (ie to be excluded/avoided). Do i just exclude defining
this logic in the code? or should i code logic statements that instruct
VHDL to avoid this situation of these inputs being both active same
time? e.g. IF (clr = '0' and pres='0') then. .......
Regards
Bk
Guest #5454779
• ▲ useful
▼ not useful
Make your FF module 'waterproof'. Catch this condition inside the module
and decide what to do, e.g. ignoring (no state change), giving priority
to clear, whatever. If this condition may drive your design in an
undefined state, you have to handle it.
Moderator (Company: Titel) #5454805
• ▲ useful
▼ not useful
> reset inputs
Are those inputs synchronous or asynchronous inputs?
If the second, then there will be big trouble toget the design running
properly...
> for a flip flop that includes clear and reset inputs
Indeed you only have exactly those flipflops already installed on the
FPGA. So have a close look to the data sheet of your specific FPGA.
Have a look there and try something similar with your toolchain:
Beitrag "Re: Hardware mit VHDL "richtig" beschreiben."
Try Google translate, its German... ;-)
  • [vhdl]VHDL-Code[/vhdl]
