OS on a fpga
OP #5452395
• ▲ useful
▼ not useful
I have hard time thinking of a fpga on which we could dynamically load
programs, from say, the internet (via a spi wifi module for example). It
would be a small and simple OS able to load and unload processes.
1) The first problem is that it would involve self modifying code (for
memory etc..), and we don't get the binary structure for fpga X or Y, as
it is closed source.
2) Even then, it may require an interruption of the system to load a new
complete image to the board, since partial reconfiguration is possible
but requires external machinery to preform the binary anyway. requires a
lot of coordination not to loose work in progress and stop everything.
3) Maybe virtual classes <-> dynamic allocation(Systemverilog) could
help but not sure about the performance.
So if some of you achieved this goal, what is the logic I should follow?
Thanks,
Moderator (Company: Titel) #5452689
• ▲ useful
▼ not useful
Your thougts are way too abstract for a FPGA...
Thinking about OSes and memory is in no way related to FGPAs, instead
its thinking about structures.
What do you want to reconfigure on the FPGA and why? Do you want to load
a new processor design during execution? Or do you simply want to load
new Software and start it afterwards?
Guest #5452724
• ▲ useful
▼ not useful
Thanks for your answer,
I plan to have one process running on the fpga, but based on the
environment, the process may need different libraries. Those would be
impractical to embed completely.
The environment varies from hours to hours and minutely in some extreme
cases.
So yes, I would like to be able to load a new process downloaded from my
servers and execute it alongside the first process.
OP #5452748
• ▲ useful
▼ not useful
Actually,
The plan is to be the most effective as possible. i want a very
personalized experience.
When looking at ARM cpus, I keep  disabling functionalities: the only
thing I want is my code executing with nothing else in my way.
But I think I could download a textual description and rebuild the
program using SystemVerilog (virtual) classes, via dynamic memory
allocation.
That would be a serious hack but maybe it could work.
My work is massively parallel.
Guest #5452774
• ▲ useful
▼ not useful
What features do you need?
What features do you want to be changeable?
What do you know about FPGA except of "fast", "parallel", "flexible"?
Do you know that there is no code operating or running on a FPGA?
Do you know that you cannot load a library into a FPGA?
Guest #5452808
• ▲ useful
▼ not useful
What you are planning is currently subject to intensive research. The
basic idea of an operating system must be considerably revised in
connection with FPGA since you have sophisticated dependencies of the
tasks (i.e., FPGA modules) w.r.t to space and time. A good starting
point may be this paper:
https://link.springer.com/chapter/10.1007%2F11682127_15
"But I think I could download a textual description and rebuild the
allocation."
I have the strong impression you have a wrong understanding of FPGA and
hardware design. There is nothing "running" on the FPGA, as discussed
here many times. During the design process, a structure is created which
is loaded onto the FPGA, where it resides during operation, but it is
never executed in some way like a piece of software. Especially the hdl
code (SystemVerilog for instance) is never executed somewhere (except in
a simulation environment). For example, if you have a piece of software
which is executed on a processor, you can stop the execution at any time
and make a statement like "Curently, the machine code of line 1355 of my
source code is executed". For an FPGA design, you can't. The FPGA
configuration is simply there, like a bunch of electronic components
that are connected in a meaningful way. You would never say that the
electronic parts in your FM radio are executed while listening to a
station.
So my advise is, make yourself more familiar with FPGA and HDL design,
and then think again about your "OS on FPGA" thing.
Moderator (Company: Titel) #5453108
• ▲ useful
▼ not useful
Mark L. wrote:
> So I am looking at something with less features by default.
Take a smaller uC with less features.
When you don't know FPGA up to now you will get in much more hassle than
you expect: the design process and strategy is totally different to all
you know. You will have to start at 0. When you don't do then you will
get back there later. Remember me ;-)
Guest #5453154
• ▲ useful
▼ not useful
Thanks, I get it.
I spent the whole afternoon reading the basics of fpga.
Yes, it is a really big subject and I confess I underestimated it. I
have been superficial.
But it may become a hobby :) in the meantime, an array of uC will do.
Thanks again,
  • [vhdl]VHDL-Code[/vhdl]
