Control brightness of LEDs using VHDL
Guest #5416491
I'm at the beginner level in VHDL programming. Recently, I would like to
develop a component in VHDL using an application with 4 LEDs connected
to an FPGA board.
By controlling the FPGA with a controlword/-byte the following functions
need to be implemented for the LEDs:
The 4 LEDs should be controllable unindependantly in brightness 10%,
30%, 60%, 85% and in frequency 0.2Hz, 0.5Hz, 1Hz, 2Hz.
The chosen functionality should be repeated until another controlbyte is
given.
Any help or hints would be much appreciated to solve the task.
Moderator (Company: Titel) #5416511
Spilt the big problem in small problems and solve them one after the
other. Connect the solved components together and you're done.
What means frequency here? Should that become a chasing light with
dimmable LED?  Or should each LED blink with it's own frequency in its
own brightness?
Where does that come from?
100% brightness is not needed?
Then a 2 bit control word for brightness and a 2 bit word for the
frequency is enough for one LED. Therefore you need 16 bit to control
each LED independently.
A question of your own? This thread is over 8 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
