Hi! In Modelsim SE 10.1a, I tried to code a counter which counts from 0 to 118 again and again. When the counter reaches #40 and #59, port ctl_1 and ctl_2 each delivers "1" for 4 period of clocks. Below is my code(also attached from files). But when I simulate, at #40 ctl_1 becomes "x" instead of "1", meanwhile, the similar #59 functions just right(wave.jpg shows that). Below is my module code. Using tasks is just for the purpose of studying, when I give up using task and simply use NBA such as ctl_1 <= 1, the problem disappears. Can anyone give any hints? Thanks!
Guest
#5386760
Does it work, if you assign the values directly, without using the tasks?
Yes, it does. Without using task, use nonblocking assignment instead, everything works fine.
Guest
#5387531
Have you tried to define the tasks before you us it in the code? Not sure if it makes any difference, but it looks like the output is undefined only on the first call of each task.
The strange thing is that I define ctl_on and ctl_off, #40 does not function right but #59 does, I have no idea what's going on...
