Width Mismatch in RAM Design
OP #5385016
• ▲ useful
▼ not useful
So the issue I am having is that on the line: "data <=
mem(conv_integer(address));" I get the following error: "width mismatch
in assignment, target has 8-bits, source has 4-bits."
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity ram is
port (
address :in    std_logic_vector ( 3 downto 0);
data    :inout std_logic_vector ( 7 downto 0);
cs      :in    std_logic;
we      :in    std_logic;
oe      :in    std_logic
end ram;
architecture beh_ram of ram is
type memory is array (0 to 15)of std_logic_vector (3 downto 0);
signal mem : memory ;
begin
MEM_WRITE:
process (address, data, cs, we)
begin
if (cs = '1' and we = '1') then
mem(conv_integer(address)) <= data;
end if;
end process;
MEM_READ:
process (address, cs, we, oe, mem) begin
if (cs = '1' and we = '0' and oe = '1')  then
data <= mem(conv_integer(address));
else
data <=  (others => 'Z' );
30
end if;
31
end process;
32
end beh_ram;
Moderator (Company: Titel) #5385034
• ▲ useful
▼ not useful
Ed H. wrote:
> error: "width mismatch in assignment, target has 8-bits, source has
> 4-bits."
Thats correct.
data is a std_logic_vector ( 7 downto 0), the RAM is a array "of
std_logic_vector (3 downto 0)".
So, what 4 bits of data do you want to store in the memory?
With this you won't get errors:
mem(conv_integer(address)) <= data(3 downto 0);
data <= "0000" & mem(conv_integer(address));
Wether thats OK to do it that way or not is up to you...
OP #5385179
• ▲ useful
▼ not useful
Lothar M. wrote:
>> 4-bits."
> Thats correct.
So I just changed the array to hold 8-bits as shown below, but now I get
an error that states "pin data[0]....[7] has multiple drivers."
library ieee;
entity ram is
port (
cs      :in    std_logic;
we      :in    std_logic;
oe      :in    std_logic
end ram;
type memory is array (0 to 15)of std_logic_vector (7 downto 0);
begin
MEM_WRITE:
begin
end if;
end process;
MEM_READ:
else
30
end if;
31
end process;
32
end beh_ram;
Guest #5385234
• ▲ useful
▼ not useful
Which Tools throws the error (Simulation, Synthesis)?
Do you really wanout direction inout at the mem?
Does your design holds a correct working Output enable (oe) control?
Do you got a block diagramm showing shared busses?
OP #5385966
• ▲ useful
▼ not useful
Synthesis throws the error.
I will attach my files. I am trying to design a Random Access Memory to
write 4’b1010 into 16 bit address location of RAM. After complete
writing, read the data out of the RAM. Also adding clock division to
this design so that the data can be read out of the RAM at 10 KHz rate
and display the address and data bus on a logic analyzer.
  • [vhdl]VHDL-Code[/vhdl]
